2014 Design
Re: 2014 Design
neilbah wrote:but in scarbs own post...
http://scarbsf1.com/blog1/wp-content/up ... SLICES.jpg
with the exception of 1a and 4a, the noses you have posted fall foul according to this. thats all im trying to say, unless you want to show why they are excluded with some clever interpretation
5a seems to have a relavitely thick central 'pylon' that could be a single section. also has 2 lower pylons to the wing.
idfx
Re: 2014 Design
The cut and the inside
I will make more pictures.
SupGiraffe
SupGiraffe
Re: 2014 Design
Re: 2014 Design
SupGiraffe wrote:first post and random crazy idea for the nose:
http://i30.photobucket.com/albums/c304/ ... kscrew.jpg
http://img.weburbanist.com/wp-content/u ... kscrew.gif
a corkscrew nose
aww childhood memories. i'm sure it would bring a good technical discussion point :mrgreen:
neilbah
neilbah
Re: 2014 Design
idfx - its not just down the center line unfortunately but anywhere to the widest part of the nose.
467
Re: 2014 Design
neilbah wrote:idfx - its not just down the center line unfortunately but anywhere to the widest part of the nose.
Up to 250mm from the centreline.
neilbah
neilbah
Re: 2014 Design
thanks for the clarification. but thats still 500mm in total so it makes any ingot shape viewed from the front difficult
Kiril Varbanov
147
Re: 2014 Design
Analysis by Mark Gillan, former chief operations engineer at Williams, Jaguar Racing and Toyota, via James Allen - http://www.jamesallenonf1.com/2014/01/e ... en-so-far/
timbo
timbo
111
Re: 2014 Design
Did I miss something? Is enclosing driveshaft into suspension arm now forbidden? All cars presented so far seem to have driveshafts open. :?
Re: 2014 Design
timbo wrote:Did I miss something? Is enclosing driveshaft into suspension arm now forbidden? All cars presented so far seem to have driveshafts open. :?
probabyl has something to do with the modified suspensions to allow usage of the suspension arms as a 'beam wing' replacement. there has to be some movement.
Mysticf1
Mysticf1
Re: 2014 Design
I know i'm pretty late to the party but I had a thought when I saw a pic of the beauty we all know and love below. Could this be a way around the nose/clean airflow issue, could someone simply raise the legality center section of the front wing to the maximum nose height and slope the fw ends down to their minimum height? Something similar to below but encompassing the fw neutral center section.
467
Re: 2014 Design
Mysticf1 wrote:I know i'm pretty late to the party but I had a thought when I saw a pic of the beauty we all know and love below. Could this be a way around the nose/clean airflow issue, could someone simply raise the legality center section of the front wing to the maximum nose height and slope the fw ends down to their minimum height? Something similar to below but encompassing the fw neutral center section.
https://fbcdn-sphotos-c-a.akamaihd.net/ ... 6916_n.jpg
No.
Cuky
65
Re: 2014 Design
are there any pictures of steering wheels from new cars? I am quite intrigued with what they all came after seeing the one from Toro Rosso
idfx
Re: 2014 Design
This design is different from my project.
My project follows this concept.
Blanchimont
Blanchimont
214
Re: 2014 Design
idfx wrote:The cut and the inside
https://lh3.googleusercontent.com/-Qf0n ... 5a-Tr6.jpg
If you move this longitudinal cut away from the car center line, you'll see two sections. That would make this nose design illegal!
The transversal cut 50mm behind the nose tip is an additional rule.
