image via Clausell_F1
Massa didn't run this front wing. It only arrived this morning.lombers wrote:It's not visible in those pictures but it appears Massa was running with flowviz on the front brake ducts whilst testing that new FW.
Sure about that? The image above clearly shows the number 6 car...Crucial_Xtreme wrote:Massa didn't run this front wing. It only arrived this morning.lombers wrote:It's not visible in those pictures but it appears Massa was running with flowviz on the front brake ducts whilst testing that new FW.
Yes I'm sure. If you look at the top picture I posted, you will see there is no hole in the endplate like the picture on the bottom or the picture you just posted.lombers wrote:Sure about that? The image above clearly shows the number 6 car...Crucial_Xtreme wrote:Massa didn't run this front wing. It only arrived this morning.lombers wrote:It's not visible in those pictures but it appears Massa was running with flowviz on the front brake ducts whilst testing that new FW.
It looks like the same FW from this picture courtesy of the F1 technical testing gallery:
Yes it does!! Wow! Very complex no?Tozza Mazza wrote:This wing has 1 5 element section!
The first flap splits into 2 about half way through!
