The mercedes "sabretooth" nose:
As far as I know, the batteries have to be in the safety cell this year.avatar wrote:Slight diversion here, but:
Does anyone else think it a little odd that the front crash structure now fits under the rear crash structure.
...so a rear end shunt is likely to lift the rear wheels of the shunt-ee off the ground, and if the shunt-ers front wheels connect with those rears, the cars are likely to lock together...
I know it's just one sort of shunt, but it's one of those unintended consequences that might come up.
Likewise, could t-boning now risk battery pack ruptures (as opposed to radiator and driver [!] ruptures with the old high noses) if the nose sneaks un under the rad's?
Neither of those accidents seems likely to happen in reality.avatar wrote:Slight diversion here, but:
You could have said the same for the following before they actually happened, but they did happen, and then became part of the argument for low nose *after* they'd happened ( if they were thought to be realistically likely before they happened, the rules would have been changed before):skgoa wrote:Neither of those accidents seems likely to happen in reality.avatar wrote:Slight diversion here, but:
I guess those will still have inlets/openings that are accessible when the tyre is off...?SectorOne wrote:I did not know where to ask this but i thought about the front brake ducts, specifically the scoop versus the sort of integrated one.
When it rains you usually want to close them off a bit due to the fact you are going slower and hence have trouble getting heat in the tires, brakes.
But how do you tape of the integrated ones? Seems like you can´t do much customization with that type of brake ducts.
Hah, that heatgun to warm the breakpads (?) is a nifty idea. Haven't seen that before.Blackout wrote:Closed/open
http://www.servimg.com/image_preview.ph ... u=14795526
And Newey didn't realise that right after new rules were planned or announced? That was the time for discussion and raising concerns. Even if they ignored him why didn't he shout from the rooftops (clear conscience)? He had a lot of time for that so I doubt his motivations. They should ban McLaren's back of the car too on safety grounds. Clearly in case of crash those additional bits can gouge someone's eye out, less bits - less chance of serious injury, simple .avatar wrote: You could have said the same for the following before they actually happened, but they did happen, and then became part of the argument for low nose *after* they'd happened ( if they were thought to be realistically likely before they happened, the rules would have been changed before):
- Mark Webber being launched over the back of Kovalainen,
- Grosjean skating over Alonso's cockpit,
- Vettle's high nose puncturing Button's sidepod and radiator etc.
P.s. I hadn't seen this article when I posted, but it seems Adrian Newey & RedBull are expressing concern along similar lines, but rather than cars locking together, they're concerned the rear end of a shunt-ee might ride up all the way to the cockpit, leaving the driver exposed to the rear crash structure:
http://www.telegraph.co.uk/sport/motors ... noses.html
