This is a screenshot from Piola's animation:
From that, can we automatically assume the drivers will have a better line of sight ? If yes, do you guys think it will make for better racing ?
No, you can't.Shrieker wrote: From that, can we automatically assume the drivers will have a better line of sight ? If yes, do you guys think it will make for better racing ?
No problems. The regulation is very confusing.Thanks for the tips.Blanchimont wrote:If you move this longitudinal cut away from the car center line, you'll see two sections. That would make this nose design illegal!idfx wrote:The cut and the inside
I will make more pictures.
https://lh3.googleusercontent.com/-Qf0n ... 5a-Tr6.jpg
The transversal cut 50mm behind the nose tip is an additional rule.
I'd also use the vanity panel to make the shorter nose back longer to have full symmetry. I think that is allowed.Blackout wrote:What if you add a vanity panel to it in order to make the nose and the 'U' sape higher?
For example:
http://www7.pic-upload.de/06.02.14/3o5zeyh3f1vu.jpg
I agree, but why Lotus didnt cover the shorter nose?turbof1 wrote:I'd also use the vanity panel to make the shorter nose back longer to have full symmetry. I think that is allowed.Blackout wrote:What if you add a vanity panel to it in order to make the nose and the 'U' sape higher?
For example:
Weight and sensitivity to damage.turbof1 wrote:I'd also use the vanity panel to make the shorter nose back longer to have full symmetry. I think that is allowed.Blackout wrote:What if you add a vanity panel to it in order to make the nose and the 'U' sape higher?
For example:
liked the idea, I'm developing. thanks for the tip.Blackout wrote:What if you add a vanity panel to it in order to make the nose and the 'U' sape higher?
For example:
No problemBlackout wrote:Brillant. Do you have a transparent render of that nose ? or a cut like this https://lh3.googleusercontent.com/-Qf0n ... 5a-Tr6.jpg ? And can you give us the dimensions of the horns? (the cross section's dimensions for example)
