McLaren MP4-29 Mercedes
Daliracing
Re: McLaren MP4-29 Mercedes
zioture wrote:Here is the second broken nose, it broke during the pitstop. 'Cause the Mclaren has not fixed this, it could be done on purpose?
https://scontent-b-mxp.xx.fbcdn.net/hph ... 4838_n.jpg
i wonder why they put the tape on the brake intakes or what they are called. does anyone knows why they do that?
Gridlock
30
Temps were on the low end of expectations so brake cooling requirements are also lower - tape is the standard way of achieving this (if you don't have better optimised ducts to hand).
#58
Daliracing
Gridlock wrote:Temps were on the low end of expectations so brake cooling requirements are also lower - tape is the standard way of achieving this (if you don't have better optimised ducts to hand).
thanks for the info i didn't know that and i've seen that many times before
Jef Patat
Jef Patat
Well, then they were very clumsy in their intention:
  • They forgot to do it with Kevin
  • The cap that broke off fell on the ground and Jenson drove over it, luckilly it was with the sharp edges down, otherwise it could've been a puncture
Rikhart
Rikhart
19
And still we havent seen the true shape of the butterfly suspension. When they were filming magnussen getting out of the car enroute to the podium I was screaming "POINT THE BLOODY CAMERA AT IT MAN"!
adrianjordan
Also using tape allows them to improve brake cooling, if temps rise for example, very easily by tearing the tape off. Using different ducts doesn't allow for this.
Favourite team: McLaren
mikeerfol
68
I was wondering, is there any reason McLaren drivers are the only ones who are using 99% throttle (According to the FOM telemetry) when flat out?
ChrisM40
ChrisM40
mikeerfol wrote:I was wondering, is there any reason McLaren drivers are the only ones who are using 99% throttle (According to the FOM telemetry) when flat out?
Part of Mclarens way to ensure they stay under the 100Kg/h flow limit?
Owen.C93
Owen.C93
177
Calibration issue. Most telemetry systems measure full throttle as 99% because then you know when they are full throttle. If it showed 100% then there's the possibility that the pedal is going further than that but not logged.
l4mbch0ps
l4mbch0ps
The other issue of course is parc ferme conditions. They are allowed to add and remove tape as they like according to conditions throughout the weekend, but switching ducts would be violating parc ferme.
Avocado
Avocado
"Significant Upgrade Package for Malaysia" sounds sweet. 8)
nace84
Last year they had a lot of "Significant Upgrade Packages", but none of them worked....so let's be cautious about that :oops:
Well testing was positive and the Melbourne Package worked well too so i'm confident they sorted their correlation out.
