Mclaren MP4-30 Honda
Fer.Fan
Fer.Fan
Re: Mclaren MP4-30 Honda
Interesting brakes. If I remember right Ferrari SF-15 have similar layout???
It would be interesting to compare. Any pictures of Ferrari brakes?
Alexgtt
Alexgtt
OK, things coming thick and fast to this car now. Very nicely integrated S-duct set up.
Anyone know if that's a different intercooler from Aus?
Am I right in thinking the other shot is a chargecooler? Would they use both?
Jashko
Jashko
Abarth wrote:
Jashko wrote:[[....]efficiency is around 99 %...[...]
That would be extremely optimistic. I don't believe that you can go beyond 96% with such motors.
And 4% of 120kW is almost 5kW of heat. Not trivial.
Agreed.
Alexgtt wrote:OK, things coming thick and fast to this car now. Very nicely integrated S-duct set up.
Not sure ... but I don't like how they weld the hot air inlet pipe to the cold air outlet pipe. I think they should separate them and even insulate the cold air outlet with aerogel wrap.
GoranF1
GoranF1
155
Heard on Autosport forums car has a "blown rear axel"
Cant confirm that whit anything just what i read there
Egresi Tamás
Egresi Tamás
ajnšpric_pumpa wrote:Heard on Autosport forums car has a "blown rear axel"
News is true... https://twitter.com/f1writers/status/581112776216731648
michl420
michl420
19
I don't think there's a blown rear axle. Every axle looks like that when it's not fully assembled.
bw1235
bw1235
michl420 wrote:I don't think there's a blown rear axle. Every axle looks like that when it's not fully assembled.
I'm not sure what the point of a blown (blowing outward, as it seems to be inferred) rear axle would be. If anything, I've though they'd want to 'suck' the air and direct inwards/rearwards to aid the diffuser seal.
3jawchuck
3jawchuck
37
http://www.fia.com/sites/default/files/ ... nt_-_3.pdf
Am I right in seeing that Alonso is still on his first PU elements? But I thought a driver shared his engines with his stand in? How can he not need anything new after Magnussen's failure last race?
emmepi27
emmepi27
141
No doubt: it's a S-duct system! =D>
3jawchuck wrote:http://www.fia.com/sites/default/files/ ... nt_-_3.pdf
He hasn't used a 2nd 1 yet. He'll have to if he wants the car to move.
can't they re-use and old engine which has been 'revised' ?
and what exactly happened to the enginge? if it was 'simply' a valve spring popping or something, then you could re-use this engine 'simply' by replacing the valves [just an example?]
F1NAC
170
Correct me if I'm wrong but they said that ICE is unrepairable
