Mercedes W11
Re: Mercedes W11
Matthew Somerfield wrote:It's not a new rear wing per se on the Mercedes but they have taken off a lot of wing and aren't running a Gurney on the trailing edge of the top flap
atanatizante
121
Re: Mercedes W11
nico5 wrote:
30 Jul 2020, 17:07
atanatizante wrote:
30 Jul 2020, 16:21
4. The last reason: with regards to the above motives and the fact that Ferrari PU is down on power (compared to 2019 unit) they are now ahead on power, although their net gains in HP for 2020 are not so big as some untrained eye could speculate ...
https://www.formulapassion.it/manifes ... 7688.html
Well, this pretty competent guy made (from telemetry) an estimate of 35-45hp more than last year in Hungary. Trained or untrained eye, it's not that little gain
Yeah, he could be pretty accurate with this figure, bearing in mind what Toto said about Ferrari which in return gained some 7-8 tenths on the straights at Spa, Nurburgring & Monza and Christian Horner saying W11 gained on average some 4 tenths on the straights in the last 3 races ... therefore, W11 PU has some 30-35HP more I should say ...
Jesus
hape
hape
Re: Mercedes W11
atanatizante wrote:
31 Jul 2020, 13:41
nico5 wrote:
30 Jul 2020, 17:07
atanatizante wrote:
30 Jul 2020, 16:21
The 7 to 8th Ferrari gained last year were of course due to a very strong engine but also because of their low drag low downforce concept. So to conclude the 30-35HP gains of Mercedes over the winter, based on data of another car concept, on different tracks, seems a little tricky.
nico5
25
Re: Mercedes W11
hape wrote:
31 Jul 2020, 16:12
atanatizante wrote:
31 Jul 2020, 13:41
nico5 wrote:
30 Jul 2020, 17:07
The analysis was focused on the very first phase of acceleration, comparing the longitudinal forces on the W10 up against the W11's, during Hungary's Q3 laps. It suggested they would gain from 0.05 to 0.19 Gs out of each corner, when 0.1G equals to an extra acceleration of 3.5kph/second, which is not insignificant by all means. Also, gear shifts would take place in a ~200rpm higher range. There's another article from today pointing at the fact Ferrari lost about 50hp through the winter, as had been suggested on Ferrari's engine thread already. They'd be now trailing by 30/40hp.
hape
hape
Re: Mercedes W11
nico5 wrote:
31 Jul 2020, 19:14
hape wrote:
31 Jul 2020, 16:12
atanatizante wrote:
31 Jul 2020, 13:41
I know, I’ve read the article and thanks for posting it. I found it interesting to read.
The gains made by Mercedes over last year is mostly on accelerating.
Returning to my remarks to anatatizante: The article estimates 35-45HP based on acceleration. He estimated 30-35HP based on the advantage Ferrari had over other cars in 2019. The latter method I think is not accurate.
zibby43
zibby43
Re: Mercedes W11
Nice comparison illustrations between the Silverstone (top) and Hungary (bottom) RW specs.
One of the main differences on the Silverstone spec wing (in comparison to even the Austria spec), was, as pointed out above, the removal of the Gurney flap from the trailing edge of the uppermost RW flap.
The Silverstone spec also has the single-pylon support, which helps to minimize flow separation across the wing, as well as reduce any turbulence on the upper side of the wing (by virtue of being mounted on the underside).
(Images/Credit: Giorgio Piola and Matthew Somerfield)
dans79
267
Re: Mercedes W11
I think this is more conjecture than anything else, but still interesting.
https://it.motorsport.com/f1/news/f1-te ... a/4848120/
Motorsport.com obtained the phonometric surveys carried out in qualifying at Silverstone: the power measurements showed surprising data. The full boost Mercedes power unit was the only one to increase horsepower compared to last year. Honda pays a gap of 28 hp, Renault pays a 37 hp, while Ferrari is last with a gap of 42 hp.
The power unit of Lewis Hamilton squeezed in Q3 showed 1,022 horses, while that of Valtteri Bottas stopped at 1,020 horses. A nothing that does not justify the gap of three tenths that the ex-champion has inflicted on the good Finnish, but which explains the impressive difference with all the others who, at least in the dry lap, just don't exist.
201 105 104 9 9 7
Holm86
249
Re: Mercedes W11
dans79 wrote:
03 Aug 2020, 21:21
How do they even calculate HP from videos??
Doesn't it take a lot of different factors like drag etc to even get a somewhat precise estimate??
LM10
LM10
122
Re: Mercedes W11
Holm86 wrote:
03 Aug 2020, 22:01
dans79 wrote:
03 Aug 2020, 21:21
If we think of the complexity of today’s PUs, it seems nothing more than adventurous to give exact numbers like for example 1022 hp for Lewis and 1020 hp for Bottas by phonometric analysis.
El Scorchio
Re: Mercedes W11
dans79 wrote:
03 Aug 2020, 21:21
Lewis has 2 extra horsepower available to him than Bottas does? Looks like all those conspiracy theories are correct after all... :lol:
dans79
267
Re: Mercedes W11
Holm86 wrote:
03 Aug 2020, 22:01
I believe what they are referring to is the use of audio analisis and gps data to estimate power. it's probably about as accurate as spitballing....
201 105 104 9 9 7
63l8qrrfy6
63l8qrrfy6
368
Re: Mercedes W11
I am pretty sure a similar analysis said Renault had 10 hp or so on Honda earlier in the season. They go to extreme lengths to generate random numbers..
RZS10
359
Re: Mercedes W11
Hoffman900
Hoffman900
219
Re: Mercedes W11
I think dyno engineers would be happy with a .2% variance.
Mudflap's comment made me :lol:
KiLLu12258
KiLLu12258
Re: Mercedes W11
dans79 wrote:
03 Aug 2020, 21:21
i thought that over 1000 horses were reached a few years ago. i mean there were some news about it like every year.
And they made that huge step now and are still only a bit over 1k?
