Juzh
161
Re: Renault V6 Power Unit
Blackout wrote:
29 Mar 2017, 14:18
According to Marko, there was no engine nor fuel consumption problems and they could have pushed till the end if they wanted.
That's funny, because raikkonen said he had to fuel save troughout the race. Perhaps marko thinks there was no problem with consumption relative to the other power units, as in they're on the same level in that regard.
carisi2k
27
ME4ME wrote:
29 Mar 2017, 11:35
carisi2k wrote:
29 Mar 2017, 08:55
I wonder if this kers upgrade will be available for Daniel's second engine in China.
What second engine? Horner said Ricciardo's car had a fuel cell problem.
On my TV when they interviewed Horner after riciardo broke down they said it was an engine problem. I have not heard anything else mentioned.
gandharva
gandharva
252
carisi2k wrote:
29 Mar 2017, 21:45
ME4ME wrote:
29 Mar 2017, 11:35
carisi2k wrote:
29 Mar 2017, 08:55
Was war bei Ricciardo los?
Marko: Am Anfang zwei Sensorprobleme im Getriebe, dann später kein Benzindruck. Die Mechaniker haben drei Nächte durchgearbeitet. Im Zuge dieser Nachtschichten kann schon mal was schiefgehen.
http://www.auto-motor-und-sport.de/form ... 50196.html
2 gearbox sensor issues and later on no fuel pressure.
I wanted to compare the RE.17's physionomy with the older Renault engines (here the 2015 spec)
The lower pic comes from Scarbs https://pbs.twimg.com/media/C70agFqXgAAtK6_.jpg
IMO the engine intake plenum seems to be placed a bit more forward (and looks to be higher) and the air-box seems to descend earlier towards the compressor and it seems to surround the plenum, whereas it used to descend behind the plenum before...
So the PU seems to be more compact.
From F1i:
Interesting 2014 Barcelona GP fuel and oil datas https://twitter.com/KevTs
CLKGTR
CLKGTR
101
Interestingly, new MGU-K is 5kg lighter which means old one was at least 12 kg (because in 2017 there is a minimum MGU-K weight of 7 kg).
That's why Red Bull RB13 is cca 5 kg over the minimum weight limit, as confirmed by Helmut Marko.
https://maxf1.net/en/renault-plans-to-i ... -possible/
roon
roon
412
Blackout wrote:
02 Apr 2017, 12:08
https://pbs.twimg.com/media/C6JC6igWgAAswha.jpg
The ERS temps (4th column from the right) of ~55°C: any guesses as to which specific component that would be? Battery pack only? Also, would a 45°-50° manifold temp be common for this formula?
63l8qrrfy6
63l8qrrfy6
368
roon wrote:
05 Apr 2017, 18:38
Blackout wrote:
02 Apr 2017, 12:08
I think 50° is just about ballpark for post aftercooler
gandharva
gandharva
252
I think the Renault powered teams currently have a huge disadvantage by running the 2016 MGU-K. In the first part of the China Race (while RAI was chasing RIC) you could see the Renault MGU-K recovering energy (flickering rear lights) way before the braking zones at the RedBull, while at both Ferraris the rear light did not light up once.
Marko said in Melbourne that the PU is slightely detuned. Maybe the 2016k is detuned because it wasnt designed to work at the higher temperatures that the new ERS can cope with...
gandharva
gandharva
252
This would make it even worse...
Juzh
161
gandharva wrote:
11 Apr 2017, 13:03
I think the Renault powered teams currently have a huge disadvantage by running the 2016 MGU-H. In the first part of the China Race (while RAI was chasing RIC) you could see the Renault MGU-K recovering energy (flickering rear lights) way before the braking zones at the RedBull, while at both Ferraris the rear light did not light up once.
Bottas was averaging 10-12 kph higher top speed on the back straight, and 10 kph higher on the main straight compared to Ric in the early stages or the race.
gandharva
gandharva
252
Renault to trial revised MGU-K in Bahrain F1 test
https://www.motorsport.com/f1/news/rena ... st-895156/
ME4ME
79
Renault is having quite a bit of unreliability issues. Luckily (unlike a certain rival manufacturer) they have 3 teams on track. Hope it all gets solved imminently so they can properly focus on performance upgrades.
http://www.auto-motor-und-sport.de/form ... 11361.html
GhostF1
GhostF1
110
Saw some photos on the STR12 thread. Noticed that the exhaust setup has changed. Do we know of any PU updates Renault were planning for Sochi?
