So what happens when you lose a significant amount of diffuser downforce in the middle of a turn during free practice when tuning?Adrian Newby wrote:I have made no such suggestion.
I can't say that I can see a groove in the floor. I can see the way the edge of the side-pod extends far back over the rear floor. The reason for this I presume is:Rikhart wrote:And yet there clearly is a groove on the floor, going from where the bridge attaches, to the back. Why is that there?Blaze1 wrote:The reason for it's design has already been described so I won't delve into that. However I believe the area in which this structure meets the floor, is outside the location in which legal cut-outs or holes are allowed in the floor and having seen numerous pictures of the rear floor and diffuser from multiple angles, there are no exits which would confirm ducted airflow to the diffuser, other than the 'undercut underpass' we already know of.Shakeman wrote: So it's just an ungainly bulkhead?
Who said it would be "actively" tuned on the track? They could just design/tune it to be faster than the highest speed corner on all of the circuits, or even each particular circuit. It wouldn't have to be as close to the cornering speed as you imply.kilcoo316 wrote:So what happens when you lose a significant amount of diffuser downforce in the middle of a turn during free practice when tuning?Adrian Newby wrote:I have made no such suggestion.
As I said a couple of pages back - most likely you wreck the car and lose at least one session!
So are you back to suggesting it be tuned exclusively using CFD/wind tunnel?Adrian Newby wrote: Who said it would be "actively" tuned on the track? They could just design/tune it to be faster than the highest speed corner on all of the circuits, or even each particular circuit. It wouldn't have to be as close to the cornering speed as you imply.
http://www.formula1.com/news/features/2 ... 11349.htmlSimon Rennie wrote:“130R will be taken flat for every lap of the Grand Prix with an apex speed around 305 km/h,”
Well, you might not use it at Suzuka then. Or you might accept a bit slower speed at 130R for faster straight speeds, or maybe the decrease in drag will get you just enough better mileage to make one less pit stop. There are many ways to skin a cat. And remember, this is basically something for nothing. If you can use it at a circuit you do, if you can't you don't. Not that hard to understand.kilcoo316 wrote:So are you back to suggesting it be tuned exclusively using CFD/wind tunnel?Adrian Newby wrote: Who said it would be "actively" tuned on the track? They could just design/tune it to be faster than the highest speed corner on all of the circuits, or even each particular circuit. It wouldn't have to be as close to the cornering speed as you imply.![]()
As for one approach for all circuits:
I'd also suggest that with such a high apex speed, the margin for stalling will be close to the cornering speed. The top speed at most tracks is not significantly greater than 300 kph. At 200 mph, your margin is only 7%.
Where can the duct exit legally be placed, when you can't really have holes in the floor.Adrian Newby wrote:Well, you might not use it at Suzuka then. Or you might accept a bit slower speed at 130R for faster straight speeds, or maybe the decrease in drag will get you just enough better mileage to make one less pit stop. There are many ways to skin a cat. And remember, this is basically something for nothing. If you can use it at a circuit you do, if you can't you don't. Not that hard to understand.
Of course it wouldn't be done in a minute. You don't think they figure things out ahead of time? I sure wouldn't underestimate Adrian Newey like that. I personally think they might have two or three different versions for different types of tracks.kilcoo316 wrote:@AN
Now - you know as well as I do that it is not the work of a minute to re-tune a car's aero-balance after making a pretty fundamental change to the exhaust-diffuser interaction.
(as in - its not the kind of thing easily switched on and off between different weekends - you'll have a completely different aero-map)
As far as I know, the exhaust blown rear wing idea is unproven and unlikely due to similar difficulties in controlling it.Adrian Newby wrote:The most basic explanation I can think of to get you to understand is that it would be like the "blown rear wing" concept, where the exhaust was aimed at the wing for additional downforce, but at higher speeds the exhaust was blown more straight back where it wouldn't affect the wing as much.
The effect would be much like an F-duct that only worked over a certain speed. And F-ducts seemed to work pretty well.horse wrote:As far as I know, the exhaust blown rear wing idea is unproven and unlikely due to similar difficulties in controlling it.Adrian Newby wrote:The most basic explanation I can think of to get you to understand is that it would be like the "blown rear wing" concept, where the exhaust was aimed at the wing for additional downforce, but at higher speeds the exhaust was blown more straight back where it wouldn't affect the wing as much.
It's nothing like an f-duct. You had a constant targeted flow with an f-duct that was digitally controlled by the driver, no matter the velocity of the car.Adrian Newby wrote:The effect would be much like an F-duct that only worked over a certain speed. And F-ducts seemed to work pretty well.
