Red Bull RB6
strad
117
Re: Red Bull RB6
A very good point about the lack of oxygen in the exhaust.
You forget the fuel they run is oxygenated. Don't ever believe the lie that they run pump gas.
Sir Stirling Moss
forty-two
Re: Red Bull RB6
Do you have a source for this information?
Shaddock
Re: Red Bull RB6
forty-two wrote:
Boost wrote:
n smikle wrote:That is similar to anti-lag right? Maybe if red-bull made their exhaust piping thicker they can do this lap after lap.
They say it damages the engine.. but they should have clarified. I am not sure delaying the ignition can damage the engine :?: I'm a little skeptical Anybody knows?
When using antilag you end up with a flame running past the base of the valve and then passing through the head. This leads to localised heating of the head and more importantly tends to burn bits of the valve away.
Could this be the reason for the famous "spark plug fault" with Vettel's car and Webber's flume of smoke at the start of the race in Bahrain (I think it was Bahrain anyway!). Perhaps a significant amount of fuel was left in the exhaust system following the Q3 run, which burnt off at the start of the race when full power was applied?
At the end of Q3 the exhaust would be glowing red at close to 1000C, and unburnt fuel would have evaporated. Maybe, the drivers have an 'overtake' button that gives them this option for a limited period during the race.
forty-two
Re: Red Bull RB6
Shaddock wrote: At the end of Q3 the exhaust would be glowing red at close to 1000C, and unburnt fuel would have evaporated.
True, if the exhaust were at 1000 degreesC, then yep, the fuel would most certainly evaporate. But we don't know what sort of clever cooling devices they might have tucked away in their exhaust package.
Shaddock wrote: Maybe, they use the drives have an 'overtake' button that gives them this option for a limited period during the race.
Or in this case, a "Stick the car to the deck when I come off the revs" button? I don't think so myself though. I have no basis for this, but it feels like it would be illegal.
Boost
Boost
Re: Red Bull RB6
They are allowed 5 different engine maps so totally legal to switch to the enhanced downforce force qually setting on the fly.
The only restriction is the map used for the start must be used for the whole of the first lap before it can be deselected.
Shaddock
Re: Red Bull RB6
The drivers do have a overtake button, that ups the revs and adds more fuel etc to give max power, whether they have linked this to a special ignition setting is an interesting idea.
If they do this, then they will be putting a lot of extra stress on the exhaust manifold and exhaust.
[youtube]http://www.youtube.com/watch?v=2wpIYQ9n ... re=related[/youtube]
They do get quite warm 8)
Re: Red Bull RB6
Residual fuel will combine with oxygen when it leaves the exhaust. If you guys are talking about the smoke and soot that is something else.
autogyro
autogyro
Re: Red Bull RB6
n smikle wrote:Residual fuel will combine with oxygen when it leaves the exhaust. If you guys are talking about the smoke and soot that is something else.
Fuel burning in the exhaust will produce flames and any wasting of fuel without producing power from it is a non starter.
Re: Red Bull RB6
Honestly I my self am a little skeptical with this claim, the parameters are temperature and flow right. I can see the air flow remaining quite similar, but temperature.. I just don't see why the team needs 1300*C over 800*C. With a turbine the extra 400*C or whatever temperature would be pretty useful, but with aerodynamics, Is the flow not attached enough? My mind just wandered on a Hot air balloon... A raise in pressure then, but still pretty minimal i suspect considering the volume is not constrained.
Shaddock
Re: Red Bull RB6
What they need to do is install one of these in the exhaust :D
not sure if this technology is banned?
imightbewrong
imightbewrong
Re: Red Bull RB6
Re: Red Bull RB6
New F-duct entries on the airbox (a la Williams/FI)
forty-two
Re: Red Bull RB6
imightbewrong wrote:Image
Looks like they're monitoring the F-Duct's operation somewhat still. Any sign of Flo-Vis being used by RB?
imightbewrong
imightbewrong
Re: Red Bull RB6
Blackout wrote:New F-duct entries on the airbox (a la Williams/FI)
Correct:
Courtesy of nextgen-auto.com
imightbewrong
imightbewrong
Re: Red Bull RB6
forty-two wrote:Looks like they're monitoring the F-Duct's operation somewhat still. Any sign of Flo-Vis being used by RB?
Something like this? :wink:
Images are from today.
