Mercedes-AMG F1 W10 EQ Power+
zibby43
zibby43
Re: Mercedes-AMG F1 W10 EQ Power+
In a recent AMuS video, Michael Schmidt mentioned that Merc were surprised that Ferrari did not have a power advantage in Q3 in France (unlike in Q2).
Seb thought it was either a change in the wind direction or that Merc finally unleashed the power of the Spec 2 engine after they ran it conservatively in Canada after Stroll's ICE failure (until the cause could be determined).
izzy
izzy
zibby43 wrote:
26 Jun 2019, 09:13
talking about that spark plug failure, has anyone seen anything about the misfire on Valtteri's engine last race? what it was?
edit in Canada on the Friday he had a misfire and it was a loss of fuel pressure
Via AMuS
LM10
LM10
122
zibby43 wrote:
26 Jun 2019, 09:13
Why would Mercedes be surprised about that, if they knew they had run the PU conservatively until then?
dans79
267
LM10 wrote:
26 Jun 2019, 20:51
zibby43 wrote:
26 Jun 2019, 09:13
Re-read what was posted!
Mercedes was surprised, Seb (Vettel) wasn't, he thought "it was either a change in the wind direction or that Merc finally unleashed the power of the Spec 2 engine after they ran it conservatively in Canada".
201 105 104 9 9 7
zibby43
zibby43
Inside of W10's front POU suspension
Via @NicolasF1i
dans79
267
What Am I missing here? It he just trying to show the difference between the front and rear?
201 105 104 9 9 7
dans79 wrote:
27 Jun 2019, 17:19
It is just different angles. He wants to show the inside of front POU suspension
dans79
267
201 105 104 9 9 7
Dipesh1995
Dipesh1995
104
astracrazy
astracrazy
31
Why would they be doing this now? Have they brought an update?
I would have thought there have been much higher speed turns than here this season already?
dans79
267
astracrazy wrote:
27 Jun 2019, 23:56
Not that I'm aware of, but they might be wanting to ensure that when they do bring one the tire can't rub. For example maybe pushing the offset mounting point even further outward.
201 105 104 9 9 7
dans79
267
I'm slightly shocked by the TIG welds on the radiator, they look fairly sloppy.
201 105 104 9 9 7
