kilcoo316 wrote:Adrian Newby wrote:You are making mountains out of mole hills.
I'm really not.
Look, the exhaust is
going to get blown farther aft as the car goes faster. It is going to happen. Period. That being the case...
Do you ignore it and hope everything works out? That seems to be what you are suggesting.
Do you aim it ahead of the diffuser sealing area so there is less sealing at lower (the great majority of corners) speeds, and more (when the exhaust has been blown farther back into the sealing zone) at higher speeds? Not the choice I would make.
Do you aim it at the diffuser sealing area so there is more sealing at lower (the great majority of corners) speeds, and less (when the exhaust has been blown farther back out of the sealing zone) at higher speeds? Hmm... that sounds better.
