Mercedes AMG F1 W04
gray41
Re: Mercedes AMG F1 W04
myurr wrote:
gray41 wrote:
gary123 wrote:http://img1.auto-motor-und-sport.de/Mer ... 669617.jpg take a look to the floor.it looks like a hole
What are the 3 "dots" just right of the wheel?
Do you mean the red dots to the left of the wheel in the picture? Looks like gravel. Or do you mean the strakes / mini fences?
The very tiny strakes.
Lewis Hamilton #44
2016
Poles: *****
Wins: ***
flyboy2160
flyboy2160
84
shelly wrote:...What I find interesting in the top view, that I had not noticed before, is that it seems that the front leg of the rear upper wishbone has the exterior layer laminated in unidirectional carbonifiber: very unusual to see, as we always see the chequers of fabric weaves.
Good pickup! They must be going for the nth degree of buckling stiffness to do that. But note that the outer portion still has a woven outer ply, so the part end trimming is still happening in woven instead of in the more easily frayed uni. I suspect that the inboard end has a similar patch of woven.
dans79
267
flyboy2160 wrote: Good pickup! They must be going for the nth degree of buckling stiffness to do that. But note that the outer portion still has a woven outer ply, so the part end trimming is still happening in woven instead of in the more easily frayed uni. I suspect that the inboard end has a similar patch of woven.
To me the outer portion looks to be a carbon/Kevlar blend. It has the yellow/gold color normally associated with a blend.
201 105 104 9 9 7
seinfeld
seinfeld
-7
they both look good in the videos. Lewis has a little more top speed, and a little understeer. hes taking long to pick up the throttle
thisisatest
thisisatest
Doesn't look like Kevlar hybrid to me. The Kevlar would be much yellower. Looks like one part of the weave is just reflecting at a stronger angle.
Upper wishbone spars look like they're molded separately from the inner and outer ends. Weave at the join near the body, then back to uni. Easier to control wall thickness inside, despite extra weight at overlap. Weave on outside, easier to drape on complex surfaces, multiple directions of load, probably some metallic hard points molded in or installed after.
Joie de vivre
What do you think are the chanses of Lewis damaging gearbox with that wall hit?
Mika1
Mika1
Zero, the car is fine. They were ready to resume Q2.
The boss follows me on twitter.
Joie de vivre
well mclaren last year in singapore also looked fine until gearbox failure in race
BlackMercedes
BlackMercedes
Looks like the conditions favoured nico, lewis couldn't get to grips with the conditions slightly wrong set up perhaps let's see tomorrow if the weather is better
Forza
238
F1 Australian GP - Saturday - 16/3/2013
mclaren_mircea
mclaren_mircea
What do you know about Rosberg's gearbox?
Yesterday thay said that it was ok, but it's very risky with the gearbox.
When such a problems appears, you may have to change it even if it runs normally, because during a race you never know.
I'm afraid that this gearbox will not resist for 4 races, and they will have to change it in Malaysia or China (if it not collapses untile than).
But if they change it than he will get a grid penalty.
What do you think? :mrgreen:
Mika1
Mika1
Joie de vivre wrote:well mclaren last year in singapore also looked fine until gearbox failure in race
I have seen a replay and the car barely touches the wall. If that would damage the gearbox, they need a new supplier.
mclaren_mircea
mclaren_mircea
Mika 1
What about Rosberg's gearbox? The car stopped on the track with a gearbox problem.
They might be forced to change the gearbox for safety, do they? Or they will risk with that gearbox for 4 races?
Mika1
Mika1
They are going to try to race with it, we will see what happens.
mclaren_mircea
mclaren_mircea
Mika 1
Rosberg said yesterday that it won't be a problem (for today), so the problems seems to be minor, and was fixed before the qualy :D
