[KVRC] Khamsin Virtual Racecar Challenge 2016
CAEdevice
50
Re: Khamsin Virtual Racecar Challenge 2016
Alonso Fan wrote:something for the homepage before Monday
http://i67.tinypic.com/e7i45g.jpg
Nice rendering and perspective view... I can't wait too see more of your car.
Alonso Fan
I will upload some more renders today once I've sorted out minor issues with the livery. Sketchup's inefficiency is making the job really time consuming and tedious to do though
SHR Modding
Youtube
Twitter
Discord
Sound Developer for Reiza Studios
Sound Modder for Assetto Corsa
pierlu99
pierlu99
Wow! Very impressive car and very nice rendering Alonso Fan. I also use Sketchup and for me, it's very difficult to make nice renderings.
etsmc
etsmc
I have tried running the test case and don't seem to be having much luck.
I installed OpenFOAM from the site and it all appears to have installed ok, I have run the runCase script and a command window opens, a lot of text scrolls down the window then it closes and the log files in the case folder are all empty.
I have tried reinstalling open foam but same result.
are there any specific/minimum requirements? does the default VM need to be running or should it start when I run the case?
Also any news on the heat exchanger rules? the only reason I ask is if the HX can not be rotated I am going to have to redesign my whole car unless the new minimum size fits in the front without rotating.
HP-Racing
HP-Racing
etsmc wrote:I have tried running the test case and don't seem to be having much luck.
How did you run the script?
RicME85
52
pierlu99 wrote:Wow! Very impressive car and very nice rendering Alonso Fan. I also use Sketchup and for me, it's very difficult to make nice renderings.
Making nice renderings is easy enough with Sketchup using Kerkythea, the problem comes when you want to do a nice livery with curves and sweeps rather than just a single colour all over with the wings in a different colour.
Alonso Fan
Precisely, hence why its taken me so long to do one, even though its simple
SHR Modding
Youtube
Twitter
Discord
etsmc
etsmc
i ran it from within windows by just double clicking it..
HP-Racing
HP-Racing
You have to start OpenFOAM and run the script with the unix terminal. When double clicking it in windows my PC also generates the files but leaves them empty.
etsmc
etsmc
and that would be done by using the OpenFOAM_start shortcut on my desktop??
because when i run that i get an APPCRASH with the application name of_start_container.exe
the same happens when i try and run the OF_Env_create
cdsavage
cdsavage
19
Re: [KVRC] Khamsin Virtual Racecar Challenge 2016
