Ferrari SF23
vorticism
323
Re: Ferrari SF23
The FW endplate strake also changed, essentially flipped upside down. Probably the LEAST important detail on this wing, though.
𓄀
dialtone
dialtone
121
Re: Ferrari SF23
This is a very different car from start of season, I'm very surprised as Ferrari hasn't brought big updates like this in such a long time. At least this big aero change signals a different development philosophy.
Re: Ferrari SF23
ing. wrote:
28 Jun 2023, 15:18
Steep angle of the floor top probably benefitting from pressure/flow field around the SIS bulge. At least that would be one unintended benefit of not having the SIS down low, even though it still looks out of place and would probably not be there if they had the possibility to move it.
Good to see the effort expended for more undercut—even if to gain a few mm’s—and get some early learning towards the 2024 car.
In my view, Ferrari is doing the same thing with SIS bulge as RB is doing with baku-spec sidepods, both are featuring an extended sidepod geometry in the low end of the undercut. Just that longitudinal location is obviously different. I don't think they will keep lower SIS within sidepods next year, but I wouldn't be surprised if they chose a concept where they still do it even with big undercut. A bit OT now, I think they will go with RB-like front part of the sidepods and then still make them wash in in the back (with further refinement of the existing geometry) and expand the tubs on the top part to something like how they started SF-23.
Re: Ferrari SF23
The flap to endplate junction now very similar to RB with the winglet on inner face of endplate & the uppermost flap element extending further rewards than the endplate, just rearward of said winglet
Endplate also now rounded rather than square (another change RB adopted for the rb19)
And here is a good angle of the new wing's flaps. There is a significant change also not just at the extremities. around the nose and its junction to the 2nd element is entirely new geometry.
Re: Ferrari SF23
The slots at endplate joint are also clearly much bigger, allowing more air to feed the bottom endplate vortex. We can also clearly see the different shape of endplate curvature (now pure outwash instead of chicane-like). The first flap chord is shorter, second longer. 4th flap is visibly bigger, but from this angle it's hard to say whether its the angle, the chord or overall planform surface increase.
29 Jun 2023, 11:25
Looks like they also have 2 new different 4th flap geometries, higher load (left) and lower load (right), lower load has no g-flap and drops down lower towards the endplate. In Fiorano they tested the higher load one.
Re: Ferrari SF23
TechF1
Re: Ferrari SF23
Re: Ferrari SF23
gordonthegun
254
Re: Ferrari SF23
This photo is from the Spanish GP, when the new sidepods were introduced.
The pull-rod entry into the bodywork is very close to the floor:
This one is from today. The pull rod entry seems in a higher position:
Re: Ferrari SF23
Shows the extent to which the floor fences now protrude
hollus
Re: Ferrari SF23
OK, sooooo... what cars (never painted in red) used to be called like in the middle of seasons in the 90s is a tad out of topic here. Those will be moved or deleted (they were moved to the team thread, even if they are also a bit off there?).
Remember, please, in the car threads, a bit more on topic than in other threads: focus on this car, this year.
Rivals, not enemies.
f1316
f1316
82
Re: Ferrari SF23
gordonthegun wrote:
29 Jun 2023, 18:41
https://cdn-6.motorsport.com/images/mgl ... ion-1.webp
https://pbs.twimg.com/media/FzzVmF9WYAQ ... name=large
Wow great spot. I’m conscious of angles and how they can fool you but looking at these it seems hard to argue against there being a difference. I wonder if there were compatible shots in Canada or if this forms part of the set up changes (inc softer suspension settings) that they supposedly found at the tyre test?
dialtone
dialtone
121
Re: Ferrari SF23
f1316 wrote:
gordonthegun wrote:
29 Jun 2023, 18:41
Nah they're the same, engine cover is very different. You can't change the suspension without changing half the car.
jambuka
jambuka
Re: Ferrari SF23
f1316 wrote:
29 Jun 2023, 20:13
gordonthegun wrote:
29 Jun 2023, 18:41
Seems to me this helps in relaxing the suspension and improving the operating window.
Re: Ferrari SF23
