Indeed. I was answering a different question.Pup wrote:The 100mm rule is the relevant one in this case.
(It seems I'm ignored here in much the same way I'm ignore by most women. At least life is consistent.)
I think it's their primary Rad cooling exit, they'd need quite a few changes to ditch it; going for the cannon exit may screw with the engine cover/packaging as there's no duct in there at the moment....Goran2812 wrote:argh why don't they ditch that bloody wide exhaust cover... it looks idiotic and is blocking airflow to the rear... -.-
Aside from the pull rod front suspension, there's no one thing that's overly aggressive on the F2012. For example, F2012's exhaust philosophy is exactly the same as that of the RB8 and Sauber C31; it's just not implemented as well.ell66 wrote:I get the feeling that ferrari tried to make an extreme/different car just for the sake of it, instead of going down the routes they know well.
Code: Select all
Article 4: Weight
4.5 Adding during the race :
With the exception of compressed gases, no substance may be added to the car during the race. If it becomes necessary to replace any part of the car during the race, the new part must not weigh any more than the original part.
Looks like refilling of the pneumatic system indeed.bhallg2k wrote: So, is the man with the hose just topping off the tank for the pneumatic valves, or is he doing something clever like raising or lowering the ride height?
As far as I know, it's not all that uncommon to refill that bottle during a race.Onch wrote:Edit: actually this is probably just a rehearsal in case the need would ever arise during a race.
Where is the port in the pictures?bhallg2k wrote:As far as I know, it's not all that uncommon to refill that bottle during a race.Onch wrote:Edit: actually this is probably just a rehearsal in case the need would ever arise during a race.
A few years back it was a rather common sight, mostly on the BMW's and Toyota's iirc.bhallg2k wrote:As far as I know, it's not all that uncommon to refill that bottle during a race.Onch wrote:Edit: actually this is probably just a rehearsal in case the need would ever arise during a race.
No they're the same as before. Brake duct is same as launch. The other piece was different in Jerez, not as shiny, but has been like that since BCN #1Hail22 wrote:This looks new?
New brake ducts with aero sensors?
and the quite large elipsal cuts under the suspension, could this possibly coming from the airbox (2nd behind main) and blowing out of here instead of the coke bottle?
Or impossible?
