This will be part of the upcoming part 2: optimisation of the endplate
Not a lot, no. Basically you are dealing with a semi-standarized bodywork piece. You take whatever is left on the table, but I wouldn't even call it crums anymore. There are maybe, emphasis on maybe, more radical ways available, one of them will be discussed in the article, but even then it's doubtful that it ultimately brings something. The endplate you see above is likely going to featured on every car next year. There's more freedom in the footplate, which says a lot.Just_a_fan wrote: ↑18 Oct 2018, 16:51I wonder how much effect the few mm on one side or the other will have on the resultant flow. I guess it all helps.
That avenue of stacking the footplate is closed off. You cannot slot the footplate anymore. The regulations give you 30mm inboard of the Virtual Endplate Surface (VES; keep that acronym in mind because it will be used constantly for the front wing regulations) and outboard the space between the VES and 1000mm from the car centre plane.godlameroso wrote: ↑18 Oct 2018, 18:21Footplate being under the endplate? Ie the triple stacked footplate TR played around with?
No idea yet - the 1.5sec/lap quoted by the media earlier this year is a little pessimistic. It's more likely in the order of tenths.Just_a_fan wrote: ↑18 Oct 2018, 16:51Any thoughts yet as to how much performance the teams will lose from the front wing changes? Also, will there be a noticeable balance shift forwards with the new front wing? I would think that the wider wing that is only wing (and therefore is all about downforce rather than flow management) and the potential loss of underbody flow quality, might lead to a forward shift. I wonder if the wider rear wing is intended to compensate for this.
Like godlameroso said, the front gets hit first with the turbulent flow. After that, the whole car basically works on straightening the flow (well, the flow that isn't pushed outboard that is), so the effect is much less pronounced at the rear of the car (still there though).Blackout wrote: ↑03 Nov 2018, 20:11Great work boys.
I have a question; Which area of the 2018 cars lose downforce the most when it follows another one? What do the drivers and engineers say? AFAIK the amount of lost DF when following, is important but it the balance shift topic is atleast as important...
AFAIK in 2016, the cars generally experienced rearward balance aero shift and became very understeery... But what about the 2017-2018 cars?
I'm not going to disagree with what's been said per se... downforce lost will impact the laptime for the following car, but the balance shift is what the drivers really feel - it delays them accelerating out of a turn and overheats the front tyres (especially the Pirelli's). The way the cars produce downforce is the same since 1984 (front wing, rear wing, underbody with diffuser) so nothing has really changed since then.Blackout wrote: ↑03 Nov 2018, 20:11Great work boys.
I have a question; Which area of the 2018 cars lose downforce the most when it follows another one? What do the drivers and engineers say? AFAIK the amount of lost DF when following, is important but it the balance shift topic is at least as important...
Interesting question... if the drag of the car is the same then the change in mass flow is the same, just in a narrower area. So reducing the width of the wake would concentrate the effect of the wake towards the centreline. That is assuming drag is the same between 2018 and 2019. I think the loss of the cascades and r-vanes will reduce drag a bit next year, I'm sure there are other variants which will have an effect.henry wrote: ↑05 Nov 2018, 16:48As I understand it the current cars, with their outwash concept, the cars drag a plume considerably wider than the car width. An objective of the new regulations seems to be to reduce the width of that plume. The question is, if the car is doing a similar amount of work on the airstream will the new cars drag a narrower plume at a higher relative speed?
If so the following car will get a bigger tow in a straight line but might experience a larger variation in performance as it crosses the wake plume?
