Mercedes AMG F1 W09 EQ Power+
Re: Mercedes AMG F1 W09 EQ Power+
Indeed. Fabrega tweeted a photo of them today. I guess they will use them tomorrow, too.
Much less blistering on Mercedes' tires compared to Ferrari
Via @AlbertFabrega
Manfer
Manfer
Morteza wrote:
09 Nov 2018, 21:14
https://pbs.twimg.com/media/DrlVBdPWwAE8pix.jpg
Via @AlbertFabrega
Hamilton ran 11 laps on those tyres where as Vettel did a 20 lap stint.
dans79
267
Manfer wrote:
09 Nov 2018, 22:15
Morteza wrote:
09 Nov 2018, 21:14
Via @AlbertFabrega
Bottas did 18 in a stint, and didn't show this kind of blistering.
201 105 104 9 9 7
230
From that video, it's hard for me to see this cooling the rim. It looks as if the rim is being heated by that flow.
Unless the passageways are coated with an insulating layer.
Cooling would make sense if the air stream came into the wheel cooler than the rim temperature. If the stream was heated by the wheel hub and brakes, then it's unlikely it will be cooler than the rim; so heat would flow into the rim.
So it would be nice to hear what is considered the flow of heat, and what is assumed to be the state of the air, hotter or colder than the rim core temperature.
Holm86
247
Wasn't the whole point to heat the rims??
Mercedes problem is blistering on the rear tires, blistering happens when the surface area of the tire gets warmer than the rest of the tire. Heating the rim, heats up the rest of the tire, so blistering is less likely to occur
siskue2005
70
Holm86 wrote:
10 Nov 2018, 13:34
if they are just heating the rims, then why should there be an heat outlet? if heating the rim was the aim then there wont be any rule bending.... as just channeling the hot air inside the rims should do the trick, without any outlet (which seems to be the controversy here)? pardon my lack of knowledge, if i am wrong please correct.
Big Tea
99
ringo wrote:
10 Nov 2018, 05:51
I think in important part of the setup is the 'insulating spacer' between the wheel and hub flange. It is not just an air flow.
ringo wrote:
10 Nov 2018, 05:51
If they wanted to heat them they wouldn't bother with all the voids and holes and just let the aluminium conduct the heat, from the hub, it's far better at heat tranmission than a tiny bit of airflow is. #-o
Now AMuS is reporting that they still won't use the rims with holes :lol:
https://www.auto-motor-und-sport.de/for ... wieder-zu/
BassVirolla
PhillipM wrote:
10 Nov 2018, 15:37
ringo wrote:
10 Nov 2018, 05:51
As I said some days ago, I think that the whole thing is insulating the rim from the hub, probably trying to avoid that the pressures raise more than desired or expected. It will align well with the problems Mercedes had with the raised minimum pressures.
230
PhillipM wrote:
10 Nov 2018, 15:37
ringo wrote:
10 Nov 2018, 05:51
Do you know the air temperature? Only then can you suggest what's happening.
Do I need to? If they needed more heat transfer there they'd make it solid, let the aluminium (with it's orders of magnitude higher heat conduction) move the heat, and give the brake rotor mounts more surface area to transmit more heat through the hub.
It'd be massively more effective.
zokipirlo
zokipirlo
-2
MtthsMlw wrote:
10 Nov 2018, 17:26
Of course they won't because it's illegal, with every week it's getting more clear. We still don't have TD on that matter...
