Sure, slip angle would be the more proper term in this case.Caito wrote:Shouldn't you care more about slip angle rather than steer angle?Jersey Tom wrote:Corner entry is transient, but often not that transient. I'd say springs, bars, and nose weight are going to have as much or more an affect than dampers.
I still like my explanation the best Temperature, transients, and all other fanciness aside... what the tire is doing at small steer angles vs large are just two totally different animals.
In a really, really fast corner you could need little steering input to generate maximum slip angle, whereas in a slow corner you need to turn the steering a lot to reach the maximum slip angle.
Of course steer angle also affects diagonal weight transfer, that's why I ask you.
Point being, I think it's wise to look for simple answers rather than going down the road of elaborate handwaving and speculation of temperature build-up and all this.
With a super simple 4-parameter formulation of the Pac tire model you can quite easily come up an example front and rear tire set that's neutral or even oversteer on turn-in and then huge understeer mid corner.
