Why not? its a car, it has an engine, it needs a transmission... surely the 911 is just as good as any other car? Whilst we all know that people on this forum are not keen on "black box" marketing claims, at least this guy is pushing ahead and getting a demonstrator built...
Iain, I assume that demonstrator will be made available to the press for back to back testing with a standard 911?
I wish you luck with this project.
Indeed Machin the 911 is a car but with a reversed transaxle.
F1 stopped using transaxles decades ago let alone one that is in effect upsidedown.
Few road cars use the layout.
Working on such a powerflow design for bench testing is not impossible but it does result in a number of costly problems that do not exist in a wiser choice of layout.
One is the problem associated with coupling a dynomometer or an 'under load' shift tester of any type.
Such 'bench' testing is essential for any proper transmission development other than for the well established and done to death stepped layshaft designs. (seperate shift mechanism tests usualy suffice for these, everybody knows the physics).
We did develop a hub dyno for the purpose, which McLaren looked at when they were developing the SLR for Merc.
Gordon Muray liked the idea when I demonstrated it for him but the SLR powertrain was finalised using bench dynos and rolling roads as these were deemed to give sufficient accuracy and the powertrain was conventional in concept.
The 'hub' dyno we developed is still not widely available and would be ideal for sorting the problems associated with F1 KERS use as well as any powertrain developments. (including the 2014 F1 8 speed compound turbo powertrains).
I have suggested this to a number of teams, however the regulations and strangely (or not) their lack of money doesnt help.
They will simply bolt in the systems given to them as usual, with little if any real development done in the cars.
I believe that test equipment like out hub dyno is essential if transmission technology is ever to improve over the current ancient concepts in use. Most new ideas are still 'suck it and see' when tried in a car.
