I have a simular idea but this solution i reused in beginning.
This solution very lowing the consistenc of whole car.
So i did something diferent.I put dampers on the tyre.If will be in tyre more dumpers can curl a tyre on curve.If tis dumpers will be hydraulic with eletronic control(like Williams from1993)can forecast surfice of track mutch faster than car with "classic" eletronic -hydraulic dumper.Dumpers can reaction on directing elements or by laser net monitoring surfice of trac infront wheel.This solution of cource have a mutch problems -in wheel must be a hydraulic pump-this is havy and complicated.
And rules of formula 1 forget on eletronic controlet tyre(there is only min. pressure).This pictures are very simply,but showing what i wrote.On first pictures can more number of dumpers and can be put diagonaly like wires in tyre.
And secon pictures showing solution on tyre with diferet rate.This a idea from Adidas smart shoe whitch eletronicly adapt rate on diferent surfices.
Eletric engine turning with shaft on reaction from directing element.
This solution is simply and effective.
