well, I would advice you to not blow the monkey seat with the hot air outlet.CottrellGP wrote:There is no real reason why, im no aero expert but i wanted the outlet to blow the monkey seat which is quite high up, at the same time i wanted the bottom of the outlet to be as tight as possible so it would blow the center of the beam wing and also let air from the side pods hit the center of the beam wing, so this was the shape i came up with. It might not work but i find the solution the best up to now.amouzouris wrote:I find the heart shaped central hot air outlet very interesting. What is the reason for that?
IIRC the car is not simulated fully (as in if the car will burn itself on the first lap) so you can decrease the size of the outlet, which I would advice you to do
