I have a theory, it is Newey's liking that they kept the dash display out of the steering wheel in early 2000sraymondu999 wrote:With regards to Hamilton giving feedback on steering wheels,
Here's the 2009 steering wheel (before feedback):
The key changes are basically that they moved the dash display onto the wheel (which happened in-season in 2009)
They removed the bottom half in 2010 due to f duct, as it made easy to pull the hand out to close and open the f-ductraymondu999 wrote:With regards to Hamilton giving feedback on steering wheels,
Here's the 2010 steering wheel (after feedback):
The key changes are basically that they moved the dash display onto the wheel (which happened in-season in 2009) and they basically just cut off the bottom part of the handles - so that they just "hang down" instead of connecting back to the "body" of the steering wheel. This happened in the 2009/2010 winter.
Yup it was used by knee initially, but at Turkey Mclren switched to hand operated one...with the bottom half cut steering wheelturbof1 wrote:The f-duct was controlled by the knee, not by the hand. Nothing to do with the steering wheel.
Yes, I knew that too (although I was under the impression it came later at the year). However, point still stands that they did not modify the steering for the f-duct, atleast not until Turkey then. Watching from the video, it remained the same steering wheel.siskue2005 wrote:Yup it was used by knee initially, but at Turkey Mclren switched to hand operated one...with the bottom half cut steering wheelturbof1 wrote:The f-duct was controlled by the knee, not by the hand. Nothing to do with the steering wheel.
watch his left hand, he is using the f-duct switch...it was discussed here back then extensively about how hand operated is better than knee
Interesting he uses entry diff settings that close for quick changes but not mid or exit.Mika1 wrote:Hamilton 2013 steering wheel tweeted by Mercedes
Look closely at the video, the wheel is intact cut off at the bottom that's the first race they raced it...there are many videos and pics you just have to google itturbof1 wrote: Yes, I knew that too (although I was under the impression it came later at the year). However, point still stands that they did not modify the steering for the f-duct, atleast not until Turkey then. Watching from the video, it remained the same steering wheel.
I am working on a small netbook screen, too difficult to notice it. I'll take it then.siskue2005 wrote:Look closely at the video, the wheel is intact cut off at the bottom that's the first race they raced it...there are many videos and pics you just have to google itturbof1 wrote: Yes, I knew that too (although I was under the impression it came later at the year). However, point still stands that they did not modify the steering for the f-duct, atleast not until Turkey then. Watching from the video, it remained the same steering wheel.
And also they have f-duct switch repositioned to side of cockpit
And I remember scarbs or someone else confirming they cut it off for easy access of f duct switch
I agree that having the display chassis-mounted was likely a Newey thing, but I also suspect there was a deliberate design choice enforced in McLaren, after Mika's crash, to try to keep the top of the wheel as clear as possible.siskue2005 wrote:I have a theory, it is Newey's liking that they kept the dash display out of the steering wheel in early 2000s
As soon as Newey moved to RBR they also moved the dash display out of steering wheel and still in 2012 it is out of the steering wheel
So I guess it was Newey who wanted it out of the wheel, mclaren just followed the trend until someone or Lewis changed it
That's odd because the layout of Hamilton's wheel this year seems identical to Schumacher and Rosberg's wheels last year. The only differences are the colours.Hamilton wrote:“It was drowning in buttons; all the ones I never use, I eliminated them,” he said. “Next I moved the most important ones to the top so they were more visible. At Mercedes there are 26 of them. I’ve already got rid of six."
Its not only colors. If you look closer the the buttons are for different things. For example Schumacher revers gear is Nico radio and Hamiltons is blanc...richard_leeds wrote: That's odd because the layout of Hamilton's wheel this year seems identical to Schumacher and Rosberg's wheels last year. The only differences are the colours.
