riff_raff wrote:Flexures can be designed to allow a large deflection angle, but like everything else it requires some compromises. A-arms are designed to react suspension loads in tension/compression. In order to allow greater angular deflection with a flexure, the flexure must be made longer and thinner to prevent excessive bending stresses. While a long, thin flexure works OK in tension, it does not work so well in compression, due to buckling.
such a configuration (pictured in LogicPro's post) seems 'naively' limited in applicability, and not optimal for compressive strength
other configurations are conceivable, just one example, the cruciform flexure, has been around for about 600 years
but there is no law that says a suspension flexure's stiffness in bending must not contribute to the wheel rate, it should contribute
that will hugely increase the scope of flexural pivoting, without complexity or increased drag
