(KVRC) Variante
variante
138
Re: (KVRC) Variante
ah, yes it is small...last year i did pretty much the same and nobody complained. However i'm convinced that it could could be done in real life as well (many teams actually did the same...maybe not as radically as me). Anyway, if someone doesn't like it, i can change it very easily...the aero advantage of the small overlap is almost invisible...
CAEdevice
49
Re: (KVRC) Variante
Don't worry, I was not complaining... I'll understand my question when my car will be completed :)
variante
138
Re: (KVRC) Variante
yeah, but again, if there's some detail that looks unfairly unrealistic, there's no problem for me to correct it...since we are talking about details :)
astracrazy
astracrazy
31
Re: (KVRC) Variante
As long as it complies with the regs then its fine.
cdsavage
cdsavage
19
Re: (KVRC) Variante
variante wrote:ah, yes it is small...last year i did pretty much the same and nobody complained. However i'm convinced that it could could be done in real life as well (many teams actually did the same...maybe not as radically as me). Anyway, if someone doesn't like it, i can change it very easily...the aero advantage of the small overlap is almost invisible...
You mean the width of the pillars? As long as they are 1cm thick you are fine (K5.6). Also as is the cockpit isnt how it should be according to the rules, but Im guessing youve changed it just for these pictures and the submitted model will be different.
variante
138
Re: (KVRC) Variante
I think he was referring to the overlap between the pillars and the neutral wing.
Just for the record: i've changed them, since those you see here don't comply with the custom made Rule K5.6, concerning pillars' area.
cdsavage wrote:Also as is the cockpit isnt how it should be according to the rules, but Im guessing youve changed it just for these pictures and the submitted model will be different.
Yes, just for the pictures. But it's still a weird choice to extend the head protections inside driver's helmet...
astracrazy
astracrazy
31
Re: (KVRC) Variante
I take it you got the e-mail reg K5.6? as your pillars would of been legal after the change
CottrellGP
CottrellGP
Re: (KVRC) Variante
Hi nice car, what program did you use to render your model?
Dan Cottrell
Master Of Innovation!
variante
138
Re: (KVRC) Variante
@astra
after some corrections, everything should be legal now.
@Cottrell
hi! nice to hear from you. I used Kerkythea (which is free and Sketchup compatible). I can give you the exact settings, if needed.
CottrellGP
CottrellGP
Re: (KVRC) Variante
variante wrote:@astra
@Cottrell
Hello! Yes would be great if you could send me the render settings, thanks
Dan Cottrell
variante
138
Re: (KVRC) Variante
Hi guys. Time for a little update concerning the livery of my car: i'm showing you the definitive version of it, with sponsors of the Khamsin competition.
You may notice some small aero updates here and there, but this is just the showcar: it's just an aesthetics exercise.
In fact i'm still working on the actual car, earning newton by newton thanks to both small and big updates. I'm looking for better results this year :D
CAEdevice
49
Re: (KVRC) Variante
It looks full of downforce :)
The "competition for engineering" stiker is not that beauty but it's not your fault!
variante
138
Re: (KVRC) Variante
Yeah..i should have made some more harmony between the stickers and the livery... But for the moment i prefer to focus on the CFD work... which, for the record, gave me a 7% improvement compared to the package you are seeing now. Not bad :D
CAEdevice
49
Re: (KVRC) Variante
It depends on the absolute values... ;) I'm taking as a reference the CFD example in the KVRC website.
I'm joking.. 7% gain in df is a great result!
variante
138
Re: (KVRC) Variante
Indeed... we're also using different set-up for our wind tunnels... therefore we can just wait for the race to start in order to see who's got the best car.
BTW, i'm happy with the rate of development so far...and i i've still got a couple of original solutions to show :D let's see...
