gixxer_drew wrote:Greg Locock wrote:gixxer drew, you friends moms car has a high cg.
It also has a short wheelbase, but I have done this in sports cars, even big front heavy and low CoG ones. The point being, theres a little more to it than the steady state calcs... there always is.
There is also a bit of difference between "low cg" in the sense of a production car and "low cg" in the F1 sense, which means less than a span off the ground.
Also, as everybody who has seen one close knows, the measure of a F1 that surprises you the most is the absurd length... for wheelbase we are talking about 330-340cm (that's some 15-20cm over that of a Mercedes S class...), that means that even with weight rear biased, the distance of cg from rear axle is still in the order of a meter and half.
So as front heavy can be, and as low cg can have the production cars you played with, still it would have a ratio between cg distance from rear axle and cg height nowhere close to that of a F1, which is in the order of 6.5-7.
