hardingfv32 wrote:So when F1 concerns themselves with measurements to the second decimal concerning aero coefficients, you do not think similar accuracy is necessary when doing suspension alignment?Jersey Tom wrote:So what?
Are you able to volunteer what level of accuracy is used in NASCAR for suspension alignment?
Brian
We would adjust indy cars down to .002 shims using nothing but string and some calipers. even a .030" error in measurement isn't that much across a 14" wheel. You are probably lucky if the wheel is still that true after a few races.
I'm not sure why you think the string method is lacking. Its pretty hard to beat for speed vs accuracy. You could bring in a laser tracker and get within .0005" but it would add probably an hour or two to setup and the car will be 0% faster. You also have a fair amount of slop deflection in the suspension components so you start chasing your tail pretty quick
