hardingfv32 wrote: ... Are you proposing something other than the normal F1 shock? ...
Probably. I think that xpensive & Tim have made very sensible suggestions.
Garry Anderson (wisely) stated that
"This type of system gives you a huge range of tweaks and can be used in many different ways". What can be seen of the assembly is counter-intuitive, at least to me. I would like to see, for example, how it is attached to the vehicle, and also what is attached (hydraulically) to the bottom of the actuator (let's call it that).
Speculating, what appears to be a flow control valve mounted at the top of the actuator might be a shut-off valve operated by a remotely connected mechanical accelerometer.
