Anybody have pics of F1 engine internals
Guest
Guest
Although the white smoke looks at the trumpets like air condensation too !
I found it as a download download it with flashget (worked for me)
mms://vipeurosport.yacast.net/eurosport/2004/07/01/F1_Renault_16871_4_25_0_320x240.wmv
Guest
Guest
Here is my collection of Engine images
The piston and the rod is from a ferrari 2001 i think (grabbed from f1atlas forums) And the lower 3 pics is from an asiatech engine
http://www.geocities.com/djgr84/collage.jpg
manchild
manchild
Very nice photos!
ginsu
ginsu
Seriously, they squirt in mid air. The variable length trumpets you see on that pic from Scarbs are in the position of highest rpm - they go upwards, closer to injectors when the engine is on lower rpm, when the vacuum is high and when the engine needs torque and elasticity. On high rpm the trumpets need to be as short as possible.
There is also a resonance that occurs due to the length of the intake trumpets, because of the pressure wave that occurs when the valve closes. And if it's timed properly by matching the length of the intake trumpet (using flow velocity, s.o.s, etc) with the frequency of pulses from the valve closing (rpm dependent, but usually where peak torque occurs) then a resonance can occur that will feed air into the combustion chamber. That's one of the ways they increase the volumetric efficiency on a naturally-aspirated engine.
I love to love Senna.
ginsu
ginsu
Anonymous wrote:Here is my collection of Engine images
I love the 'serrated edge' for the con-rod and big-end cap on the Asiatech engine. Great way to increase the surface area. New Honda K20 motors actually crack the caps off to ensure maximum surface area (because of the surface roughness of the cracked piece). I believe this is for cooling, but it is just as useful from a structural standpoint as it ensures better bonding between the surfaces.
manchild
manchild
Renault piston
manchild
manchild
I found these today looking for something totaly different :lol:
*make sure you enlarge pics because they are high res and worth seeing*
F2000
DaveKillens
DaveKillens
34
There are basically two ways to design how the surfaces of the rod bearing halves mate. The older, traditional method was to machine each surface as flat and smooth as possible. The second way, favored for higher strengths, is to "crack" .. mechanically split the middle of the bearing, and leave each surface untouched. This way, when reassembled they mate like pieces of a jigsaw puzzle, each microscopic dip and bump meeting it's opposite on the other surface. This results in much improved mechanical bonding.
manchild
manchild
Pistons and con rods in previous post and now I've found crankshaft from same engine :wink:
For those who'd like to blow $US 1,499.99 (Euro 1,198.75) on this crankshaft here's the link http://www.ferraristuff.com/en-us/p_2183.html
