I just found out Max Mosley had the same
Idea already. That's all the proof I need to know I had a bad idea.
This hasn't been the case for a few years now, regardless of DRS. The combination of the narrower rear wings, neutral element on the front wing has all but removed this problem.Pierce89 wrote:
You're kind missing the inability for f1 cars to put on a proper race. The car behind is always automatically disadvantaged. That seems dumb to me.
I think the lack of "good" racing (or at least what I enjoy) in this series is more a function of [a] disparity in performance, crap tires, [c] few if any full course cautions. Though to be fair, I only caught bits of a handful of F1 races this year.Pierce89 wrote:You're kind missing the inability for f1 cars to put on a proper race. The car behind is always automatically disadvantaged. That seems dumb to me.
How embarrassing for you, sir!I just found out Max Mosley had the same Idea already. That's all the proof I need to know I had a bad idea.
Jersey Tom wrote:I think the lack of "good" racing (or at least what I enjoy) in this series is more a function of [a] disparity in performance, crap tires, [c] few if any full course cautions. Though to be fair, I only caught bits of a handful of F1 races this year.Pierce89 wrote:You're kind missing the inability for f1 cars to put on a proper race. The car behind is always automatically disadvantaged. That seems dumb to me.
I still think some of the better open wheel racing I've seen in recent years is at the Indy 500, maybe last year's is what I'm particularly thinking of. Lots of slip streaming and a more even field => more quality passes.
That's simply not true. I don't remember who, but one of TDs said at two carlengths back they lose 10% of DF and at one carlength back they're losing 17%. That's better than the 25% they lost pre2009, but the trailing car still loses a massive chunk of DF.Tim.Wright wrote:This hasn't been the case for a few years now, regardless of DRS. The combination of the narrower rear wings, neutral element on the front wing has all but removed this problem.Pierce89 wrote:
"Keep a 4 sec. distance, otherwise you destroy the tyres.."Tim.Wright wrote:10% isn't much at all when you consider the same effect gives the following car a top speed advantage due to the slipstream.
When was the last time you heard a driver complaining that he couldn't follow someone because of the dirty air?
I haven't heard it at all since the reg changes in 09. We used to hear it every race before then.
That's pretty much unavoidable unless you want them to run Nascar style aero, or reduce speeds to below 50 km/h. It wouldn't be F1 anymore if either of those things happened.Pierce89 wrote: You're kind missing the inability for f1 cars to put on a proper race. The car behind is always automatically disadvantaged. That seems dumb to me.
Wouldn't be a thing that people say if the tires didn't degrade so fast.el-Magico wrote:"Keep a 4 sec. distance, otherwise you destroy the tyres.."
It's not a bad idea due to Max Mosley. It's a bad idea because it's a bad idea.Pierce89 wrote:I just found out Max Mosley had the same
How could they do that with a plank wear test, though?bill shoe wrote:It's not a bad idea due to Max Mosley. It's a bad idea because it's a bad idea.Pierce89 wrote:I just found out Max Mosley had the same
The problem with this system is that it gives optimum overall laptimes by putting on lots of downforce and then accepting a very artificially low top-speed along the straights. You gain all the time back (and more) with the downforce advantage in the corners. Basic sims of typical Tilke tracks confirm this.
Cars would drone along the straights at steady-state speeds that were limited by the underplank rather than the ability of the car to propel itself.
I'll go out on a limb and say Mosley was correct that limiting downforce via arbitrary dimensional limits on bodywork was/is crazy and irrelevant to anything outside racing. Just don't like his solution to that problem.
Sorry, do what specifically?Pierce89 wrote: How could they do that with a plank wear test, though?
