Turbocharger assisted Aerodynamics in 2014 and beyond
neilbah
neilbah
Re: Turbocharger assisted Aerodynamics in 2014 and beyond
how about the turbo is used as a jet engine with afterburner #-o lets not get silly
Pierce89
shelly wrote:From compressor straight out to the exhaust could be an option maybe
With the new exhaust placement, it'd be nigh on worthless.
shelly
shelly
136
I am not so sure - but this time of the year I like to dream about wild developments
twitter: @armchair_aero
Shaddock
wuzak wrote:
Shaddock wrote:They must be exiting the air from the DV/blow off valve into the exhaust system if this is the case.
If they have them at all.
If you don't put one in it will add lag to the the turbo and potentially damage the blades during the surges.
240
Pierce89 wrote:
ringo wrote:well those res say all air going into the engine.
It doesn't say all compressor air must go into the engine does it?
Those are rules for inlets, not outlets. :wink:
All fluids leaving compressor must exit the exhaust. That means the only place you could squirt compressed air is in the engine or straight out the exhaust. I don't think it gets much clearer in FIA terms.
where is that in the regs?
474
5.8.1 With the exception of incidental leakage through joints (either into or out of the system), all (and only) the fluids entering the compressor inlet must exit from the engine exhaust system.
474
n smikle wrote:
wuzak wrote:
n smikle wrote:In the 2014 season we will have precious, pressurized air from the turbochargers to do our evil deeds of cheating the rule system.
Can you say off throttle blowing of wings? Or on-throttle wing stalling? Compressed air brake and wheels cooling?
The Lotus DRD is a prime candidate for making use of compressed air from the turbo charger.
Lets see some designs folks!
Cannot use the air from the compressor for aerodynamic purposes.
hmmm
hmmm what?
If you have an incidental leakage that just so happens to feed into a duct that takes it to a wing for aerodynamic purposes then I feel that the FIA would take the view that the leakage wasn't so incidental.
474
Lag will be dealt with by the MGU-H.
The MGU-H will also be used to control the speed of the turbo to control the boost.
Holm86
249
I'll quote something I wrote in another thread.
Im not quite sure about the blow-off.
But I suggested something earlier this year which would also remove much of the need of running a blow-off valve.
I suggested that they should run cold blowing of the engine if that is allowed in 2014. This means when the driver lifts off the throttle pedal the throttle plates should open 100% instead of closing as normal. This would keep a higher flow through the turbo so you can harvest more energy with the MGU-H. It would decrease pumping losses which would decrease natural engine braking effect which allows the MGU-K to harvest a larger procentage during braking. And last it would prevent the shockwave moving backward from the throttleplate to the compressor when the throttleplate closes. The fuel and ignition would off course be cut.
IMO it should be legal as there is no aerodynamic advantage from cold blowing next year with the new exhaust exit regulations.
And when it comes to the turbo assisted aero I think the regulations are pretty clear. Just like wuzak pointed out.
neilbah
neilbah
as with the blown exhaust era could we still see throttles left open most of the lap to aid exhaust flow keeping the exhaust spool and negate the need for pressure relief valves on the inlet side..? probably been discussed in the engine thread, excuse me if so but its heavy reading. damn sumone beat me to it :)
If you open the throttle you would have more pumping losses. Unless you had variable valve timing all that extra air you are sucking in is going to take more energy from the pistons to compress it. The extra energy now, would come from combustion.
If cold blowing the exhaust is your goal, then you cannot escape pumping losses. Pumping loss in it self is not that bad of a thing when u are cold blowing because the cold blowing is usually done while under braking.
39
Not necessarily. If the throttle plate never closes all the way (cold blowing) you would not need a DV/BOV and would be able to keep the turbo spooled up.
Hmm.. You are giving new ideas now.. 8)
the air is compressed, therefore after it is used, it can be reintroduced in a low pressure state back to the exhaust stream.
Holm86
249
n smikle wrote:If you open the throttle you would have more pumping losses. Unless you had variable valve timing all that extra air you are sucking in is going to take more energy from the pistons to compress it. The extra energy now, would come from combustion.
That is not true. Yes you need more energy to compress more air. But you get almost all of it in return in the "combustion phase" where there is no combustion but the piston is still forced down by the compressed air just like a spring.
Holm86
249
neilbah wrote:how about the turbo is used as a jet engine with afterburner #-o lets not get silly
Actually the turbo could be run as a jet without going out of the regulations I think. Not with afterburner though :D But there would be no reason to do this as the power generated by this "jet turbine" could only feed the MGU-K with 160 HP.
