Lotus E22 Renault
mikeerfol
68
Re: Lotus E22 Pre-launch Speculation
Trocola wrote:The first non-pen*s car. Thanks god.
Looks great
Yeah, the first co*k car :P
Btw
@ScarbsF1: Not sure how Lotus make the twin tusk arrangement meet the reg "a single external cross section of more than 9000mm² "
Gridlock
30
Re: Lotus E22 Renault
They're not the same length, right? It's not just some intern with little concept of perspective?
#58
scarlet
scarlet
Yep, right tusk looks longer to me.
outer_bongolia
I would love to see this lotus lock a McLaren nose to nose. That'd be a nice view.
Skeptical scrutiny is the means, in both science and religion, by which deep thoughts can be winnowed from deep nonsense.
Carl Sagan
Blanchimont
Blanchimont
214
CBeck113 wrote:Interesting that they made the nose asymetrical, but I can't believe that the FIA let them get away with it (i.e. aerodynamic function of the vanity panel, which must be the shorter side of the nose) ... there will be many changes before the second test, since this solution will be much better than the Williams & McLaren solutions.
It's also possible that both fingers belong to the crash structure. But why do you think that the Lotus solution is better than the others? The rules demand that you the cross section 50mm behind the tip has to have a minimum cross section of 9000mm², that's the cross section of the right finger. The second finger increases the cross section from 50mm behind the tip onwards and also doubles the turbolences and weight.
bidong
bidong
outer_bongolia wrote:I would love to see this lotus lock a McLaren nose to nose. That'd be a nice view.
how to make a 2015 f1 car. make babies
atlantis
atlantis
21
Is that nose legal?
scarlet
scarlet
And I don't think it's guaranteed that you'll get more airflow through under the car with this design anyway.
beelsebob
beelsebob
85
Nope, it appears lotus are exploiting a loop hole here. There's nothing in the crash structure regulation that says that it must have a *single* cross section. Only that it's total cross sectional area must be 9000mm².
astracrazy
astracrazy
31
wtf is that. what is this sport coming to
Blanchimont
Blanchimont
214
beelsebob wrote:There's nothing in the crash structure regulation that says that it must have a *single* cross section. Only that it's total cross sectional area must be 9000mm².
15.4.3:
... It must have a single external cross section, in horizontal projection, of more than 9000mm² at a point 50mm behind its forward-most point. ...
Me too thinks the Lotus sidepod inlets seem to be smaller than the Merc powered cars (williams and Mclaren atleast)
But wait an see
beelsebob
beelsebob
85
15.4.3:
Nope.
15.4.3:
It must have a minimum external cross section, in horizontal projection, of 9000mm2 at a point 50mm behind its forward-most point.
http://argent.fia.com/web/fia-public.ns ... _20.07.pdf
atlantis
atlantis
21
Is it me or the right part of the nose seems shorter than the left?
Blanchimont
Blanchimont
214
beelsebob wrote:
15.4.3:
Nope.
15.4.3:
Better use this one: http://www.fia.com/sites/default/files/ ... -12-09.pdf
