I guess he means the lateral G's seen by a car while turning are a function of both the car weight and downforce composed into the vertical lodas on the tyres, doesn't he?richard_leeds wrote:Aero downforce does not create g-force. One is an externally applied load (N), the other is an acceleration (m/s2) due to change of velocity.n smikle wrote: G-forces ...are not solely due to aero-dynamic down-force ...
No I appologize for being that agressive. You got it right tho. Human body has problems to cope with vertical G-forces, that's right, such as negative-G force which is probably the worst case. Vertical force the other way such as these experienced by oval racers is easier to manage, but if you look at jet-fighter pilots, some have pressurised suits to forbid the blood to go down to their feet, which is as bad as having all the blood in your head in case of negative G forces.xxChrisxx wrote:I tried to clarify this in my earlier post, becuase I realised it was ambiguous.MadMatt wrote:Wrong. Where on earth do you have a longitudinal component when driving at constant speed on a banking? You are talking about VERTICAL component. Sorry but sometimes I get tired of reading sh** on a forum such as F1 technical.xxChrisxx wrote:Banked tracks means the g force has a longditudinal component. Its also important to make the distinction between dizzyness and g induced black outs.
Im also not blindly dismissing the possibility it could happen. Its just that I seem to remember that humans can tolerate lateral g far better than longditudinal g.
I didn't use vertical becuase that is being ambiguos w.r.t the banking or the ground, though it is less confusing that me calling it longditudinal. I suppose 'component prependicular to the banking'/'vertical axis of the body'.Edit. I should clarify. Longditudinal in this case means the axis going from head to foot.
Really should have been more careful with how I described it, sorry.
quite low levels of negative g cause temporary or permanent damage to the eyes etcMadMatt wrote: ..... jet-fighter pilots, some have pressurised suits to forbid the blood to go down to their feet, which is as bad as having all the blood in your head in case of negative G forces.
