@ lycoming
I'm not going to quote your text..... but please....do explain your contradictory post. Is it tyres, downforce or .... just plain uncertainty.
So how does totally removing one thing (downforce) "redress the balance"?FoxHound wrote:Eliminate a reliance on downforce.
Simply eliminate it.
Hererin lies the rub my fellow plebians, does one over emphasise one discipline over the over for so long that it becomes "acceptable formula" or do you redress the balance to accomadate the other disciplines?
Big ass question.
A diffuser and a Venturi tunnel are so close to being the same thing that they might as well be the same thing. Teams have recently been reluctant to implement the latter due to its increased sensitivity to ride-height changes. Take too much of a curb (or "kerb" for those of you who drive on the wrong side of the road), and the sudden increase in ride-height results in a sudden, massive reduction in downforce. The driver then loses control of the car.Töm87 wrote:All they'd have to do is ban diffusors and replace them with venturi tunnels.
But i guess that's too difficult for the morons of FIA
They tried this a few years ago and it didn't work. Possibly because the dirty air is causing a loss of downforce from the undertray rather than the front wing.acosmichippo wrote:My thought has always been why not supplement DRS with a switchable "Additional Downforce System" on the front wing for racing in dirty air.
Read the post again. At no point did I say "totally removing" "one thing"(DF). Of course some DF is required.Just_a_fan wrote: So how does totally removing one thing (downforce) "redress the balance"?
All you'd end up with would be modern versions of cars from the 60s. If you want to watch 60s cars, go watch some historic series.
Having said that, watching 60s cars with 2014 powertrains would be fun for a few minutes - soon get bored of watching cars spin in to the gravel the first time the driver got even slightly enthusiastic with the throttle...
There was already a (probably) perfect solution proposed. Of course the teams voted it down reflexively.ringo wrote:For some time now it was believed that reducing the downforce of the cars will increase overtaking by allowing the cars to follow much closer.
Now We see that the 2014 cars have less downforce, but things have actually gotten worse. Because of the low grip, drivers are finding it harder to follow another car because they tyres are degrading faster, and the cars grip is being affected even more than before.
So what is the real solution..do they increase downforce even more where there is so much grip that losing some by following does not affect the total much?
Or do they reduce downforce to a point where there is little and following in dirty air doesn't affect it much because there isnt much to begin with?
What's the solution to the following and overtaking debacle?
False. This year's tires are better than last year's. Tires can only hurt the race if you need to protect it constantly. Which sucked last year, not as much now. The aero prevent car from closely following each other. (Plus the huge differences in overall performance)Lycoming wrote:Don't blame the aero for something that's caused by tires made from a wet paper bag.
Nonsense. Not true. You can overtake in a slipstream without the one in front making a mistake. Also at breaking if you manage to get to it's side. But you need to be able to follow close enough.marcush. wrote:have you ever attempted to overtake a car with similar Performance envelope by following closely ? this does not work at all .Overtaking is either a matter of the Driver in front in Trouble ( mechanical ,fuel consumption temps whatever) or making a mistake .
you can try to pressure the Opponent into making a mistake -but guys like Hulk or Schumacher do not make mistakes when defending .They have it pretty much under control due to peripheral awareness anticipation and strategy (they act ,they do not react as this is not allowed within the rules)
So brings us back to square one overtaking is not a matter of cf Brakes aero or weight -or power it is a matter of Deltas in Performance envelopes -does your car Nurse the tyres without compromising lap times , could you use traffic and clever tactics to save some kers or ERSH energy when your Counterpart could not add to this DRS and you got an overtake Situation.
would one want artificial overtaking ? I think it makes sense if there is no way past even if you are 2 seconds quicker than the guy in front.
Nope. Tires are least of the issue.Rikhart wrote:You want more overtaking? Make better tyres.
You don't. Just the decreased wind resistance in the slipstream should be enough.mrluke wrote:i.e. if you can follow within <0.5s you only need a small power advantage to get past,
Bigger rear wings are counter intuitive. The generate the most turbulance. More like no front wings and very little rear wings. In my opinion.rjsa wrote:+ smaller front wings and big rear ones.Töm87 wrote:All they'd have to do is ban diffusors and replace them with venturi tunnels.
But no one will touch the diffuser, I don't get it.
The problem with passing has been for a while the loss of front DF from the wake of the car ahead on the following one's front wings. They even tried a lift producing center section and moving flaps to counter it.
While in the back the diffuser is working all the time.
One would assume that the drivers wouldn't be all incompetent... Much like in the sixties. Simply they would only use full power in really long straights. I can imagine it as a B formula so I could watch two drastically different style races instead of one.Just_a_fan wrote:Having said that, watching 60s cars with 2014 powertrains would be fun for a few minutes - soon get bored of watching cars spin in to the gravel the first time the driver got even slightly enthusiastic with the throttle...
That's only the issue if you have sideskirts that touch the ground, right?bhall wrote:A diffuser and a Venturi tunnel are so close to being the same thing that they might as well be the same thing. Teams have recently been reluctant to implement the latter due to its increased sensitivity to ride-height changes. Take too much of a curb (or "kerb" for those of you who drive on the wrong side of the road), and the sudden increase in ride-height results in a sudden, massive reduction in downforce. The driver then loses control of the car.Töm87 wrote:All they'd have to do is ban diffusors and replace them with venturi tunnels.
I agree: leave the downforce as is, but increase the power if the driver wants it.ringo wrote:The downforce can be left at this level, but maybe the cars need 1000hp to force mistakes from drivers...
