Belatti wrote:Computers aids for road cars are done for average users. A skilled driver will always do better.
False. I don´t think the above example is correct, as ABS is not that good, on some situation it could even be a problem. Snow, mud, gravel... here no ABS will be way more effective as locking wheels provide extra drag. And even on tarmac a skilled driver can do as good as ABS
But ESP is definitely something no driver can do. Not even Sebastian Loeb can control a car as ESP does. Breaking single wheels as ESP do provide yaw control, something a driver can´t do no matter how good he is. We´d need to control front and rear brakes separately to do so. And front-rear brakes distribution can´t help here
We have some yaw control with the front wheels, but not even close to what ESP can do braking one single wheel, only the one needed at a time, the difference is huge. Moreover, with front wheels we have control only to some angle, once the car has spun more than that angle, front wheels have no control over the car, while ESP will control the car no matter what angle it is skidding
If you´ve not tested ESP I recommend you to do it. I did once there was a good layer of snow on an empty and wide parking, and it´s awesome how ESP can control the car direction even when it´s skidding the four wheels moving 90 degrees sideways, you just need to move the wheel and the car will spin to that direction the same as if it would be rolling normally. With ESP off you can move the wheel all you want to any direction that the car will continue skidding sideways, no reaction.
It´s a fun and enlightening test
