Yes, it was an optional extra I believe. Gave 20 more hp with the increased boost possible.langwadt wrote:The Saab99 turbo S from the late 70's was water too I believeTommy Cookers wrote:seems the right time to mention ......
what was called WI in aviation was actually a mix of methanol and water
post WW2 there was (still is ?) an agreed standard mix (GM would have used this eg in turbo Corvair)
WI in 82 or so F1 was water only
Water had to be mixed with alcohol for wintertime use.
Yes, the methanol is only to prevent freezing.Just_a_fan wrote:As a guess, the methanol helped to reduce freezing of the water at altitude.Tommy Cookers wrote:seems the right time to mention ......
