I agree, that's why I would like to here about some possible scenarios, not the wild speculation the thread has had so far.Shrieker wrote:Quite honestly the first team to come to mind is Merc. This is definitely a very interesting topic.
Well if it isn't Merc that's doing this... we are so screwed.Shrieker wrote:Quite honestly the first team to come to mind is Merc. This is definitely a very interesting topic.
Wrong!dans79 wrote:. . . No one has even proven how a team could make something. . . .giantfan10 wrote: sinple logic says its mercedes
ferrari was dominant..... suddenly testing was banned and so on
red bull was dominant... suddenly the blown diffuser was banned
see the trend?
Reducing the pressure in the lines will cause lighter components of the fuel to vaporise if the pressure is reduced below the vapor pressure of that component. This would potentially allow ALL THE FUEL between the flow meter and the pump at the engine to be used for a short term power boost.
I just did a quick check on the compressibility of gasoline. Its bulk modulus is 1.3 x 10^9 Pa. If you take the extreme case of an in-tank pump capable of 500 bar pressure and operating between 50 and 500 bar to compress the fuel between tank and engine, the density of that fuel will vary by a little over 3%. If the lines hold 1 litre that is a variation of 30cc. Remember, this is just the fuel compressing, flex in the lines is extra.
Based on your old calculationgruntguru wrote: Wrong!Reducing the pressure in the lines will cause lighter components of the fuel to vaporise if the pressure is reduced below the vapor pressure of that component. This would potentially allow ALL THE FUEL between the flow meter and the pump at the engine to be used for a short term power boost.I just did a quick check on the compressibility of gasoline. Its bulk modulus is 1.3 x 10^9 Pa. If you take the extreme case of an in-tank pump capable of 500 bar pressure and operating between 50 and 500 bar to compress the fuel between tank and engine, the density of that fuel will vary by a little over 3%. If the lines hold 1 litre that is a variation of 30cc. Remember, this is just the fuel compressing, flex in the lines is extra.
Do that means for every 1 cc they are getting 3% of Power boost, soIf someone is scamming the rules, it would be very easy to custom make some "flexy" fuel lines.
Fuel flow is 28 g/s say 35 cc/s. One extra cc per second is a 3% power boost.
Your list contains actual parts or features of dominant cars, the fuel thing isn't one that is known. (Were it to exist.) The split turbo on the other hand is so your logic actually forbids teams from running that.giantfan10 wrote: sinple logic says its mercedes
see the trend?
“The engineer Enrico Benzing has written two articles published on our magazine FormulaPassion.it on the issue of fuel consumption in Formula 1. In a Formula 1 that makes of consumption one of the nodal points of its technical regulations, it’s normal that media and readers pay the utmost attention to this issue. In particular, we wonder what the reason is for the lack of official FIA communications on the value of the fuel’s specific weight, a datum that many believe essential for full transparency in applying the regulations.
In fact, the Federation has set two limitations: the first is relevant to the fuel on board: max. 100 kg. The second regards the instant consumption that cannot exceed 100 kg/hr. during a Grand Prix. A measure that the debimeter takes in liters/hr. to translate them into kg/hr., resorting to a preset conversion index based exactly on the specific weight. It is clear that any variation of such index based on the fuel used by the teams can affect, positively or negatively, the value identified by the debimeter, hence the car’s performance.
We would be grateful if you could help our readers to understand the FIA position on this issue.
These are the links to the two articles of the engineer Enrico Benzing
http://www.formulapassion.it/2015/01/f1 ... el-motore/
http://www.formulapassion.it/2015/01/f1 ... onosciuto/
This is intriguing.gruntguru wrote:I just had another thought. Reducing the pressure in the lines will cause lighter components of the fuel to vaporise if the pressure is reduced below the vapor pressure of that component. This would potentially allow ALL THE FUEL between the flow meter and the pump at the engine to be used for a short term power boost.
but surely with the necessary reduction in pressure to cause vaporization, there won't be a big enough pressure gradient for the fuel to be injected?Abarth wrote:This is intriguing.gruntguru wrote:I just had another thought. Reducing the pressure in the lines will cause lighter components of the fuel to vaporise if the pressure is reduced below the vapor pressure of that component. This would potentially allow ALL THE FUEL between the flow meter and the pump at the engine to be used for a short term power boost.
A combination of flexing fuel lines, and playing with the pressures, could well give some remarkable "boost".
All you provided was the results of a basic math calculation, that's not based on any of the real world operating parameters.gruntguru wrote: Wrong!Reducing the pressure in the lines will cause lighter components of the fuel to vaporise if the pressure is reduced below the vapor pressure of that component. This would potentially allow ALL THE FUEL between the flow meter and the pump at the engine to be used for a short term power boost.I just did a quick check on the compressibility of gasoline. Its bulk modulus is 1.3 x 10^9 Pa. If you take the extreme case of an in-tank pump capable of 500 bar pressure and operating between 50 and 500 bar to compress the fuel between tank and engine, the density of that fuel will vary by a little over 3%. If the lines hold 1 litre that is a variation of 30cc. Remember, this is just the fuel compressing, flex in the lines is extra.
This is what's often referred to as using an accumulator (as mentioned above) and it si forbidden. These last few posts seem to make a case for an implicit accumulator in that the fuel lines "swell" from pressure - thereby accumulating some fuel for later use.George-Jung wrote:Would it be possible to 'collect' the fuel after it passes to fuel-flow-meter.. in order to use this 'collected' fuel latter on during the race to have some sort of boost?
All coolant pumps, oil pumps, scavenge pumps, oil/air separators, hydraulic pumps and fuel
pumps delivering more than 10bar must be mechanically driven directly from the engine
and/or MGU-K with a fixed speed ratio.
