machin wrote:The electric cars also have an advantage over the ICE's; no performance degradation at altitude...
Not the case this time for the winner, as it lost half the power
machin wrote:I would disagree slightly; I'd say Power:weight is what is important for a hill climb car... And whilst you might say I'm being pedantic, it is worth noting that even 5 years ago an electric car could not be anywhere near an ICE-powered car in power:weight terms... Whereas now they're essentially there or thereabouts.
Indeed
Actually they´re well over most powerful ICE-powered cars. Loeb´s Peugeot was 875hhp with 875kg, this one is 1368bhp with 1190kg, well over 1000hp/ton (1150)
And contrary to what some people said above, this actually proves the contrary, it´s not all about power or power/weight ratio, weight is still important, and the car itself, and the driver. This year winner is a lot more powerful and with better power/weight ration than Loeb´s Peugeot, but they still are 50 seconds behind. I´d have loved to know what time they could do without those problems tough
Anycase I´d say driver and weight (315kg difference) are still the two main factors they´re far from Loeb´s time.
machin wrote:IThe electric cars also have an advantage over the ICE's; no performance degradation at altitude... There is a reason that the top drivers are turning up in electric cars these days and it is only partly down to marketing...
As much as I love electric setups, I must say current batteries still lack enough energy density. But even so they´re showing some awesome perfomance, so imagine when some new battery (Lis, LiO, Graphene based batteries...) finally solve their problems... the perfomance jump will be inmense
PPIHC winner battery must be around 400kg, any of the new batteries under development will improve energy density by a factor of 2 at least. That means battery weight will be reduced to a half. Imagine same car, with same power, and 200kg lighter, what actually will be more as they could same some weight on chasis, suspensions, etc.
That´s the reason many drivers and teams are turning up in electric cars, like it or not they´re the future so better if you start learning about them asap
