2 to 3% fuel burn reduction on a typical airline flight. An example can be the 737-800 series. They don't come from the factory with the vertical winglets. Those are made by a separate company and is considered an STC (supplemental type certificate). There was shown to be about a 3% decrease in fuel consumption over the average trip by the addition of those winglets.Tommy Cookers wrote:2-3% compared to what ? (I wonder on these occasions)trinidefender wrote:2-3% is for the first generation of wingtip fences and the like similar to what is seen on Airbuses (except the A350). The latest generation such as the extended and raked wingtips as seen on the new Boeing 777, and winglets seen on the 787 and a350 are worked out to be up to 5%.riff_raff wrote: ...... commercial aircraft companies have committed substantial amounts of money and effort over the past few years to address the similar issue of wing tip vortices ....
The current generation of wing tip designs used on commercial aircraft like the 787, A350, A320 NEO, or 737 MAX reduce cruise fuel consumption by 2-3%. .....
and 2-3% in cruise is useful, but maybe 1-2% of overall fuel use
younger readers might not know that all this stuff was explained by Lanchester in about 1895
so designers have been deciding wrt extent and rake or taper of wings more-or-less since then
(eg the new aircraft in flight rather resemble the DC-3 (or DC-2 really), of 85 years ago)
the dominant factor in these decisions is often evolution (or lack of it) in various airfield space factors
extended tips have been made to do no lifting in cruise (handy if you're extending an existing wing)
tip vortices are an inevitable symptom of lift or DF and a measure of its inefficiency
2d flow producing pressure differences that we call lift or DF
these pressure differences cause 3d components of flow (ie spanwise) - the tip vortex, a waste of energy
though not inevitable if the lifting surface is of skirted DF venturi tunnel type
this will develop inherently less 3d flow
with a decent aspect ratio and maybe extra internal 'lane divider' skirts this will give a better ratio of DF to wake size/energy
handy for car racing
the cars would need to be of TARF, Nardi, (or Yunick ?) 'catamaran' layout (to accomodate the venturi tunnel centrally)
yes, I have seen the pictures in bh's posts
Note however they are not an easy retrofit. The outboard portion of the wing has to disassembled and then extra structural work has to be done on the wing to support the extra available lift that can be produced near to the wingtip. It is only then that the tip, extra lights and the rest of the panels can be added back on.
