bhall II wrote:FoxHound wrote:dans79 wrote:Down-force only improves overtaking, if it's not sensitive to turbulent flow. Over the last 2 decades, the rules have pushed the teams into using increasingly more sensitive methodologies. This is the reason you hear drivers complaining about it being hard to pass even though they are faster.
And also why going down the mechanical grip route is a no-brainer for me.
Ya know, a not-unreasonable argument can be made that mechanical grip is bad for overtaking.
Red: Massive aero dumbdown, slick tires, no change in overtaking
Yellow: Refueling ban, less mechanical grip due to narrower front tires, sizable jump in overtaking
Green: DRS, Pirellotteri-style grip,
obscene jump in overtaking
Orange: Sharpest decline in overtaking in 30 years despite DRS and continued refueling ban, pit stops fall from
1,111 to
~725
Blue lines: 2016's likely overtaking range, aka "Holy hell, I can't wait for the shitstorm of complaints after the sport's ill-informed opinion-makers blame 2017's inevitable high-speed funeral processions on increased downforce."
Ill informed like people designing these cars with thousand times more valuable data than drawing questionable conclusions from graphs? Why questionable:
1. Putting some facts together is not science, you need correlation that includes other factors. 1990 is very different from 2013, same for every jump
2. Connected to the above - the dumbed down issue is not if mechanical grip is better than aero at improving overtaking (or rather not making it more difficult = not the same) but if specific aero changes of '17 don't affect overtaking and if the alternative of mechanical grip improvement would be better.
3. More importantly, not included in your graph and connected to point 2 - the issue is faster cars, means to achieve them and if making car faster by 2-4 s (?) from '15 to '17 through aero rules is the best way. Faster cars AND overtaking which is not worse, not overtaking itself.
I like the fact that F1 engineer A. Costa is not making "100% certain" claims about aero '17 impact, weighs his words, questions the changes and talks about the possibilities but here something opposite: "no-brainers" and "ill-informed" gets you hundreds of points. "Makes sense if you think about it: everyone loves wet races (when mechanical grip is at a premium)". 1. No, not everybody loves wet races. Ill -informed
2. No - probably, depending what you mean by "premium" but tyres are also at premium and so is aero. Admittedly I know nothing about it but I did watch races and I have 2 real life and recent examples:
A. wet USA race when similarly simple claims were made about RB vs Merc and aero vs engine balance.
http://en.mclarenf-1.com/index.php?page ... 0Ricciardo Rosb vs Ricc
Code: Select all
9 1:57.162[2] 1:56.930[4] +0.232 -1.267 6
10 1:58.183[2] 1:57.870[4] +0.313 -0.954 7
11 1:58.149[2] 1:58.220[4] -0.071 -1.025 4
12 1:58.969[2] 1:58.214[4] +0.755 -0.270 8
13 1:58.141[3] 1:56.680[2] +1.461 +1.191 9
14 1:56.677[3] 1:56.898[2] -0.221 +0.970 5
15 1:56.172[3] 1:55.362[1] +0.810 +1.780 10
16 1:56.329[3] 1:54.685[1] +1.644 +3.424 11
17 1:55.790[3] 1:54.650[1] +1.140 +4.564 12
18 1:56.124[2] 1:54.194[1] +1.930 +6.494 13
19 1:55.927[2] 1:54.143[1] +1.784 +8.278 14
20 2:13.229[2] 2:18.388[1] -5.159 +3.119 6
21 1:47.466[2] 1:49.539[1] -2.073 +1.046 7
22 1:46.148[1] 1:48.350[2] -2.202 -1.156 8
23 1:43.999[1] 1:46.473[2] -2.474 -3.630 9
24 1:43.534[1] 1:46.060[2] -2.526 -6.156 10
What conclusions about mechanical grip/aero (constant for RB/Merc cars) can you draw from it, which is better, premium impact during lap 9, 19 and 21? Not that simple if the assumption is that 1. Track conditions changes in connection with aero/engine balance are not enough to explain change of pace like that. 2. Pace wasn't consistent: Merc overall slightly slower, then RB considerably quicker, then Merc considerably quicker. Check pace later to add more data to that.
B. dry Spain race when car/tyre characteristics described as "sliding" made overtaking more difficult than in '14 (assumption) with only slightly different aero and some tyres changes. Tyres - harder, aero combination: plus side overall development, minus side nose rules, combined unknown, either way not a big change.
So wet and dry races not comparable and number of wet races considerably lower than dry races = bad example.
