bhall II wrote:Blaze1 wrote:Yes, I considered that ride height sensitivity could play a part, but noticed that no pre-1993 IMSA GTPs (prior to the mandated flat floor section under the driver) were designed with raised tunnel throats. There is a video interview with the designer of the Porsche 956, where he stated that unlike single seaters, it was necessary for the throat of the tunnel in this specification of car, to be fed from airflow along the sides of the car. That simply feeding from air entering under the nose had pretty much no impact. Perhaps this may be one of the reasons that a lower throat was necessary?
It's difficult to speak to a designer's intentions with regard to underbody flow in the early '90s, because the subject wasn't particularly well understood at the time - and it remains the least understood piece of the puzzle today.
My best guess is that the IMSA guys were perhaps exploring force enhancement from edge vortices to varying degrees - overview below - while the F1 guys were busy with active suspensions. But, that's just a guess.
http://i.imgur.com/tqVuLED.jpg
From
Ground Effect Aerodynamics of Race Cars
http://i.imgur.com/dtbQU0c.gif
Thanks bhall. That excerpt from Xin Zhang's study actually managed to answer some of my questions on the fly, pertaining to skirts.
When Norbert Singer mentioned that airflow needed to come from the sides, I didn't considered the connection with vortex generation along the side of the tunnel. I assumed he was referring to a wide throat with its outer edge placed at the cars maximum underbody width, so the flow is encouraged into the tunnels via the side of the tunnels throat.
Like this.........:
..........rather than this:
(This is a model of the 962 underbody, which is very similar to the 956s)
Also interesting are the smooth transitions from the wall to ceiling of the Nissan P35's tunnels.........:
.......These would seemingly contradict/mitigate the concept of vortex generation, however an elegantly sculpted strake has added for that purpose one would imagine.
bhall II wrote:Incidentally, that highlights the misnomer of exhaust-blown diffusers, especially designs from 2010 to 2013. The concept was never intended to "seal" the floor; rather, exhaust gasses were used to energize edge vortices, which allowed for more aggressive diffusers and rake angles.
I think the "specialized press" was way off on that one.
http://i.imgur.com/n9RybKq.jpg
http://i.imgur.com/BIet568.jpg
There does appear to be quite a significant difference in rake between the Mercedes W04 and the W05 - W06, with 2013 car exhibiting the greater angle.
bhall II wrote:As for McLaren's design study, it just looks like a funky, highly stylized double-diffuser to me. Air flow would be accelerated by the floor's curvature and turning vanes around the leading edge before being extracted by the secondary diffuser at the rear of the car. If effective - big if - it would just move the floor's aerodynamic center to an area that's closer to the middle of the car.
Do you mean the area circled here:
