New chicane to be added at Monza?
bdr529
59
Re: New chicane to be added at Monza?
Never liked that chicane, it doesn't seem to matter whether it's F1, sportscars or bikes.
it's just to dangerous having two 90 deg. corners in such close proximity at the end of a very long and fast straight,
it puts the guys at the front in the position of "sitting ducks" waiting for trouble from behind, especially at the start of a race
flynfrog
I like it without
mzivtins
mzivtins
Re: The F1 news FUD topic!
Facts Only wrote:
Per wrote:
According to this article the reason for this additional chicane is so that LMP1 and SuperBikes can go straight at the first chicane, which is a bit too tight for them now.
This sort of thing really naffs me off (not the post but the sentiment of certain people in Motorsport), if the chicane is too tight then the car hasn't been designed properly. Its not the tracks fault is it? Monza has been like this for years and on the calender long before the cars/bikes in question were designed. The cars should be designed for the competition they are entering, not the other way round.
Lets go back to the banked curves that monza used to have and see how we get on, tracks need to evolve surely?
Plus it is optional, and the more heavy braking zones, the more overtakes :)
mertol
bdr529 wrote:Never liked that chicane, it doesn't seem to matter whether it's F1, sportscars or bikes.
https://www.youtube.com/watch?v=hk0frTQfHG8
The new chicane won't be any better in regards of being a sitting duck but that's easy to solve - just put a big, thick wall of tires on the inside like 100m before the chicane.
It concernes me what will happen around that new chicane they plan. I expect they will cut a lot of trees and will cover everything in asphalt maybe even the outside of curva grande.
strad
117
We would get on just fine.
Sir Stirling Moss
RicME85
52
http://www.racingcircuits.info/pro/news ... 03Qm5ErKUl
Monza's proposed new first turn and chicane will be used for cars and not just bikes after all, if plans submitted to the Lombardy regional government come to fruition. The new high speed turn one would bypass the Curva Biassono (commonly known as Curva Grande) but would also see the removal of the finickity Rettifilio chicane on the front straight altogether.
The idea of using part of the abandoned Pirelli test course to form a new first corner and chicane complex drew adverse comment from many fans when it was first floated earlier this year. Fears were expressed over the potential loss of Curva Biassono with a feeling that such changes would inevitably lead its use by Formula One and other car races - points refuted by circuit sources when the plans first came to light in Gazzetta dello Sport in January.
But now a document published on the Lombardy regional government's website* under environmental planning laws shows no differences between the layouts for car and bike use, with the current Curva Biassono set to disappear under asphalt run-off.
The plans, penned by Italian circuit designer Jarno Zaffelli's Dromo company, are intended to bring Monza up to both FIM Grade A and FIA Grade 1 status (currently it has only the latter) ahead of the resumption of World Superbike (WSBK) races at the historic venue in 2017. Described as a "discussion document", the papers describe how a variety of options were considered before settling on the proposed solution, quoting Zaffelli as saying that it would allow for a "proper revamping of the track, both for cars (F1 included) and bikes, with particular attention for WSBK."
The new section of track would also lead to a reduction of speed into the Variante della Roggia chicane and allow the use of lower curbing favoured by the motorcyle racers, with revisions to run-off areas, kerbing and barriers also proposed at the Lesmo, Variante Ascari and Parabolica. These have been carefully calculated using Dromo's specialist DroCAS system.
The plans also talk of an innovative system of warning lights being built into the track surface at various points to warn riders and drivers of dangers ahead, while a new service road would aid the quicker removal of stranded vehicles following collisions. A new CCTV control system would also allow race directors to detect when competitors cut corners, as is frequently the case at the current chicanes.
It remains to be seen if permission is granted (around 400 trees are thought likely to need to be felled) or indeed if F1 ever runs on the revised course - negotiations for Monza to continue on the calendar beyond this year are continuing, with the major sticking point likely to be raising the finances necessary to extend the current deal.
DiogoBrand
74
Have they not learned from Spa that chicanes with elevation changes are ---?
And I don't need to mention any example to say that adding a chicane in the middle of one of the great turns of the circuit is also a terrible idea.
It's because of geniuses like that that F1 seems to be going ever backwards.
I like that layout. The current chicane is horrible. Think of F1 cars going around that curve at 340km/h and then fighting to get it all slowed down for the chicane. That will take some doing and makes for some balls-out overtaking attempts.
Just rewatched the LMP1 video above - getting rid of the chicane and running the full curve would also be cool. =D>
Anything is better than the current chicane imo.
Both this one or a return to the pre 2000 design would be welcome for me.
BanMeToo
BanMeToo
DiogoBrand wrote:Have they not learned from Spa that chicanes with elevation changes are ---?
What's so good about curva grande?
Jolle
Jolle
133
This solution looks a bit like how on "our" zandvoort track, they have the option for a chicane before "Het scheivlak", a very demanding corner, with a braking point on top of a small hill, turn in downhill and in 3rd right, almost blind. A corner where everyone holds its breath.
Wonderful for cars, not so much for bikes. So they added a small but effective "right-left-right" just before the normal braking zone, so "Het Scheivlak " becomes one big corner exit.
SectorOne
I think its worth a shot.
The first chicane is complete garbage anyways.
Lower curbs sounds even better!
zac510
zac510
22
Can we get rid of Seconda Variante too?
No good turn goes unpunished.
BanMeToo
BanMeToo
Some more details.
http://www.f1fanatic.co.uk/2016/06/01/n ... cars-2017/
For me it's hard to imagine 100% of these things actually happening, especially the parabolica gravel.
Getting rid of the first chicane is a good move in my opinion, glad I waited until I learned more before speaking my mind. It's going to lower lap times because the new chicane will be a bit faster, but now the only passing will be on the straights, hopefully the extra length on the front straight will allow a decent slingshot.
*I think the additional changes improve the circuit as well from a safety standpoint. They seem to be moving the walls of the two lesmos further inward to improve visibilty through the corners. And the nicest part of the renovation is that although they're still going to have tarmac run-off on the parabolica there's going to be gravel too. Which is a decent compromise in my opinion.
