bill shoe wrote:Good quality information from all, definitely thanks. I am most interested in differential torque as the only means of steering a car rather than as an occasional or supplementary method or as part of an ESC system. This is because ESC-based differential torque just needs to keep the car stable in an emergency, it doesn't need to feel intuitive or good. Steering feel and response need to be very good in order to be a good high-performance control mechanism for human drivers. I don't know if or how this could be done with differential torque. Admittedly, human drivers are a very old-fashioned perspective in 2016.
I forgot to add the RLX non Hybrid has P-AWS, meaning the rear wheels can toe in independently depending on driver needs.
The Hybrid system uses electric motors to torque steer the car, meaning more power transmitted to the wheels that will enable greater turn speed through the corners. Even the simple mechanical system acted in similar ways.
https://youtu.be/KzQKjQR9u0A
The Ferrari FF also used a similar awd setup
