Net horsepower
Mikey_s
Mikey_s
Maybe it's nothing to do with bendy wings at all, perhaps Ferrari just have an extra 2 engines hidden on board!! :lol:
Mike
Reca
Reca
93
Ciro Pabòn wrote: Drag Power = 5.4 * (318/3.6)^3 / (2 * 746 ) = 2.500 hp :lol:
It would be nice for someone to correct this.
First of all on our beloved planet standard air density is 1.225 kg/m3, not 12 kg/m3, thank God I would say ;-) so the first coefficient would be 0.5 * 1.225 * 0.9 = 0.55 and not 0.5 * 12 * 0.9 = 5.4
Then you divide it by 2 while you shouldn’t (you already included the 0.5 in the coefficient 5.4).
Consequently you get something about 5 times higher than your assumption of SCd = 0.9 m2 should lead to.
Ted68
Didn't someone post that old Car & Driver test of the Jaguar F1 somewhere? They had the acceleration numbers listed. you could easily put those values into one of the many 1/4 mile calculators on the web and have the answer in a few seconds. That is if Ford/Cosworth were honest with the power numbers they gave the magazine.
Ciro Pabón
106
Ted68 wrote:Didn't someone post that old Car & Driver test of the Jaguar F1 somewhere? They had the acceleration numbers listed. you could easily put those values into one of the many 1/4 mile calculators on the web and have the answer in a few seconds. That is if Ford/Cosworth were honest with the power numbers they gave the magazine.
I have kept the Car & Driver figures, given in an unusable html format in an Excel sheet at my site. You can find them here. But I have no 1/4 mile figures for F1's... I guess is around 7.5 seconds.
Ciro
m3_lover
I will look today and put it on later today, I have the magazine
Simon: Nils? You can close in now. Nils?
John McClane: [on the guard's phone] Attention! Attention! Nils is dead! I repeat, Nils is dead, ----head. So's his pal, and those four guys from the East German All-Stars, your boys at the bank? They're gonna be a little late.
Simon: [on the phone] John... in the back of the truck you're driving, there's $13 billon dollars worth in gold bullion. I wonder would a deal be out of the question?
John McClane: [on the phone] Yeah, I got a deal for you. Come out from that rock you're hiding under, and I'll drive this truck up your ass.
jgredline
Wow, Bench racing at its finest.
To finish first, first you must finish.
Ciro Pabón
106
Oops. I did not posted the URL for the Car & Driver Excel sheet: there you go.
Ciro
Frenchblock
Frenchblock
hp's sells cars, torque wins races! :wink:
Jersey Tom
Jersey Tom
Eh, not entirely. Figure how much torque an F1 car puts out.. assume they make 750hp at 17000rpm... that's only 230ft lbs of torque. You can have a high-revving, high-power car with relatively minimal torque like in F1 and just gear it down to get absurd amounts of thrust, or you can have a low-revving, high-torque car like the R10. Each has its benefits and is suited to different styles of racing.
wazojugs
Frenchblock wrote:hp's sells cars, torque wins races! :wink:
Once you have shifted the cars weight you don't need a lot of torque.
BHP is the figure to have when track racing
jgredline
I can't think of one form of motor racing where torque wins races. Its all about Hp. If we want to make this very technical and overly complicated it is not possible to make Hp with out a torque increase regardless of RPM. Hp is the result of torque at a given RPM. A flat torque curve will give you a broad HP/RPM range. A torque monster like a chevy or ford V8 will not make a lot of Hp because of the lack of revs. Even in Nextel Cup racing its all about RPM. RPM=HP. In some series like the IRL where there is a rev limiter, then you will work backwards and have an engine that will peak at 10300RPM and because of the short revs will make more torque than if it had a rev limit say 14000 rpm. In either case its still all about Hp. Not torque. I know someone will say, well the Renault engine had a lot of torque and its did/does, but it also has a lot of Hp because its revs. They simply have the best engine right now as much as hate to say it.
Tom
I put that in an earlier post i think, so true. Any yob can quote BHP figures but how many of them know what torque is?
(was discussing the plausability of inserting a Rolls Royce Merlin into a Citroen AX with said yob and when I revealed it was in fact a V12 from the Spitfire plane he, to my amazment, suggested it would have nowhere near enough torque to power the little car!!!)
Murphy's 9th Law of Technology:
Tell a man there are 300 million stars in the universe and he'll believe you. Tell him a bench has wet paint on it and he'll have to touch to be sure.
Jersey Tom
Jersey Tom
Area under the torque curve wins races? Any takers?
Edit - and I might add the Merlin is a sweet engine!
jgredline
Jersey Tom wrote:Area under the torque curve wins races? Any takers?
Explain what you mean??
flynfrog
a broad power curve makes the car more drivable
it has more power in more places than a peaky power curve
you can get by with less gears and ussaly drive harder out of a cornner
why do you think f1 has 7 gears they make all of there power in a verry narrow area
