Formula 1 Aerodynamics - article series and general discussion
pierrre
pierrre
56
Re: Formula 1 Aerodynamics - article series and general discussion
get your hammers out, finished this on modern sidepod on formula one cars...i guess the term modern in formula one only last a year or more only...oh well
Intertwining vortecies! AKA helicity.
Slo Poke
Slo Poke
What is the reasoning behind these Vortices? What possible structural integrity do they possess and at what rotational speed do they acquire any such integrity? As car speed increases along any straight, a vortex generator adds to unwanted drag and different corners require different speeds. So what is the thinking here?
A Vortex is not a Tornado! Even those things need and need to obey atmospheric whims.
pierrre
pierrre
56
well it certainly is something the formula one aerodynamicist are playing at. observing the edges along the side floor, the frontal area has a raised kink while behind it are gratings that actually look to draw air downwards, going the opposite direction. put two together and it looks like they are trying to generate vortex along the side of the car...most probably to seal the floor
They've been running vortices along the car for some time. It's hardly a new idea so not sure why you're suddenly querying it. An example:
As for vortices adding drag, yes they do. But they allow greater downforce to be generated allowing higher cornering speeds. Thus improving lap time. Again, not a new idea.
variante
138
pierrre wrote:
12 May 2020, 10:22
Good job, that's a nice explanation.
But it seems that a couple of things were out of focus (minute 5 or so): the downwash effect is not there just to fill the gap left by the outwashed flows, but it is actively contributing to downforce production. In fact, the downwashed air can be used to build up pressure on top of the floor and to offer the Rear Wing a better Angle of Attack, neutralizing the detrimental upwash coming from the Front Wing.
pierrre
pierrre
56
variante wrote:
16 May 2020, 11:29
pierrre wrote:
12 May 2020, 10:22
thanks for the compliment
see what you mean by the flow curve in total that goes over the car from front would come down at a steeper angle on the rear wing as the side pods open a larger space behind it earlier too and encourage air downwards..primarily though i do believe these designers are focused on the floor
bosyber
bosyber
45
Good stuff Pierre!
I am not sure a) whether this is the right place to post this (since strictly speaking, it's about the last generation of front-wings), and b) whether it has been posted around here already, but, it looks interesting enough for me, so:
Note that it's actually a thread with several more images
jjn9128
779
bosyber wrote:
18 May 2020, 14:21
Good stuff Pierre!
https://twitter.com/TimoteoBriet/status ... 7635257344
Without wanting to be snarky analysis of a front wing should be performed at least with front wheels. But preferably with a quarter model (nose and wing hangers/turning vanes up to the cockpit opening). Otherwise it's pretty meaningless.
#aerogandalf
bosyber
bosyber
45
jjn9128 wrote:
18 May 2020, 14:37
bosyber wrote:
18 May 2020, 14:21
Good stuff Pierre!
Yes, I do agree, apart from pretty pictures, I took this as a first step to see what the wing does on it's own (I am also assuming it is at least mirrored right now), before putting a static, then rotating, wheel in there; when looking at cornering, it would definitely first need those wheels, and possibly a nosecone as well.
One wonders why teams don't do more to try to encourage the helicity of the counter rotating vortecies coming off the back of the car. Maybe they do, and they can't do more because of the regulations. I notice the shape of the diffuser encourages air to travel towards the center area of the diffuser, and then spin on the way out.
The wastegates being placed near small winglets are driving the air coming off the back of the car into the path of the vortex as it's helped along by the rear wing center section, that vortex, then turns direction, and the other half is partially trapped in the rear wing outer edge, and endplate.
Where the diffuser kicks air up and counter clockwise when seen from the rear, the rear wing and end plate adds to this, because the pressure on the top side of the wing is higher, and lower underneath, therefore high pressure air from the rear wing will travel downward along the endplate to the underside of the wing where the pressure is nice and low. The slots and the way the endplate flares out increases the pressure on the outside of the end plates making the inboard area more attractive to the free stream air. This airflow can further enhance the vortex being shed by the diffuser, as can the suspension fairings.
One of the benefits of the raised suspension is that it allows a fairing over the suspension that can create small vortecies that help the main one.
There are many ways vortecies can merge, not only can they merge to become a stronger single vortex, they can also split off and reform, as well as "french braid" together. The latter doing a good job at adding angular momentum of the vortex core.
https://www.irphe.fr/~ledizes/web/CRAS2005.pdf
Here's a thought, can vortecies interact similar to mechanical gears? Where one can turn the other, and phenomena like gear reduction and mechanical advantage are present?
Holm86
249
godlameroso wrote:
18 Feb 2021, 17:12
I think not, won't they always try to merge, to find a pressure equilibrium??
Holm86 wrote:
18 Feb 2021, 17:37
godlameroso wrote:
18 Feb 2021, 17:12
Do the two counter rotating vortecies from the diffuser merge?
Holm86
249
godlameroso wrote:
18 Feb 2021, 22:11
Holm86 wrote:
18 Feb 2021, 17:37
godlameroso wrote:
18 Feb 2021, 17:12
I think two vortices rotating the same direction will enhance eachother, two rotating opposite direction will cancel eachother out.
If you have one more powerful/larger than the other, I think they will ad up so you end up with a V¹+V² or a V¹-V² if that makes sense ?
