nosles on engines i do not understand
pyry
pyry
whats the fuel/air ratio typically in a f1 engine? compression ratio might be somethingg like 11-13?
does the regulation dave posted mean that direct injection is forbidden?
four rings to rule them all
manchild
manchild
Yes, direct fuel inj. is banned.
Regarding fuel/air ratio in F1 it can be changed during the race to add performance or save fuel. MIXTURE switch on steering wheel enables driver to choose level suggested by team via pit radio. Before two-way telemetry was banned teams were able to adjust engine parameters from pits and all driver had to do was to acknowledge new settings by pressing button.
http://video.google.com/videoplay?docid ... 9926133763
pyry
pyry
ok, but whats the point in banning fsi? that would be a bonus on performance, as well as contributing pretty directly to fuel economy as well as having a direct link to production car technology.
i was already aware of adjustable fuel air ratio, but was wondering what it is generally and whats the possible variation and its effect on power/fuel ratio?
DaveKillens
DaveKillens
34
For gasoline fuel, the stoichiometric air/fuel mixture is approximately 14.7 times the mass of air to fuel. Of course, with different air densities and that additives in Formula One fuel, it's probably slightly different.
Burn at this ratio, you get maximum fuel burn, max power. Lean it out and the combustion chamber gets hotter, you get slightly better fuel mileage. Richen the mixture, you run cooler, and of course, just waste gas.
zac510
zac510
22
pyry wrote:ok, but whats the point in banning fsi? that would be a bonus on performance, as well as contributing pretty directly to fuel economy as well as having a direct link to production car technology.
That would be logical, but I believe they were afraid one team would get a too big advantage from it and the others would have enormous costs to spend catching up.
MrT
MrT
14.7 to 1 is indeed stoichiometric fuel ratio, however this does not yeild maximum power. When fuel is atomised by the injectors the dropplets are larger than the air molecules. This means that there is some fuel at the center of the droplet which will not burn properly. This is why richening yeilds more power, as a richer air fuel ratio (0.88 lambda, or 12.1ish A/F) yeilds the correct SURFACE INTERACTION area between the air and fuel rations so that a real stoichimetric ratio of fuel actually combusts.
Teentardpojo
Teentardpojo
Phoenix
Where is the combustion happening?
Woody
Woody
Word of warning, don't click on the link in the above post or any similar as this is a trojan that will download onto your PC and start sending personal information.
pyry
pyry
the link is a bit out of context anyhow, maybe a mod could remove it? :)
Phoenix
Can anyone tell me where the combustion is happening in the Renault video?
manchild
manchild
As in any 4 stroke engine - in cylinder. What you see on video is just a mist as the injectors spray fuel into trumpets.
Phoenix
Okay. I was confused on what I was seeing moving. I assumed that waht I saw moving in the hole was a psiton, but is it correct to say that its a flange like that of a throttle body?
pyry
pyry
there would be quite a dramatic failure in the engine if you can see the piston moving :)
manchild
manchild
Phoenix wrote:Okay. I was confused on what I was seeing moving. I assumed that waht I saw moving in the hole was a psiton, but is it correct to say that its a flange like that of a throttle body?
That's old V10 with butterfly so what you saw was a butterfly moving. Theoretically, you could see a piston moving trough such type of throttle body but that would require different angle of viewing and only few rpm or super fast eye.
