2018 in-season testing thread
digitalrurouni
digitalrurouni
Re: 2018 pre-season testing thread
So seems like the wings are just wider and the end plates look a little less developed? Is that it?
Sieper
73
the additional "on top" layers seem to have been banned".
It's raining now :D Didn't see that coming
https://twitter.com/WilliamsRacing/stat ... 1684912128
digitalrurouni
digitalrurouni
Still too many elements on the wings if you ask me. We need a drastic reduction. What I am mainly concerned about is if this will help the cars follow each other better or not!!
senja
senja
That Red Bull wing is not 2019 wing.
senja wrote:
31 Jul 2018, 17:16
It's a simplified 2018 wing as Scarbs stated.
ismail1991 wrote:
31 Jul 2018, 10:23
Will wider wings without cascade sand simpler endplates in 2019 be able to generate equal downforce with the current wings?
The cascades and endplates don't generally generate downforce on the front wing (the wing converature and endplates do help in maintaining airflow in curves and therefore downforce). They're controlling airflow around the front wheels and guiding air to the diffuser in the rear. With the front wing changes, banning blown front wheel hubs and restricted brake ducts; they're basically banning the manipulation of air flow in the area outside of the front wheels and confining them to the space between the front wheels.
mkay
mkay
16
diffuser wrote:
31 Jul 2018, 18:55
ismail1991 wrote:
31 Jul 2018, 10:23
Will this in theory work well with Mercedes' current design (less reliant on sealing the diffuser like Ferrari/RBR)?
In my opinion Merc, Ferarri and RBR are all using similar designs. Merc's isn't quite as integrated because of doing it mid season. Likely a large redesign coming in the off season there. Along with barge board/mid wing increase length rules coming into effect.
TAG
Phil wrote:
16 May 2018, 13:06
Take a look:
https://pbs.twimg.com/media/DY4pgUsXcAAHI17.jpg
Monaco is mechanical grip all the way.
Thanks for this Phil, it actually hit my square in the face and explains why Merc have a much easier time getting the soft compound to work... it has a high working temp range like the Medium.
माकडाच्या हाती कोलीत
mantikos
mantikos
GPR-A wrote:
31 Jul 2018, 16:10
Could they not have restricted the front wing to have only 3 elements? There are still way too many elements on that wing.
Why? Do you want to make it a stock series? Why take away all the fun?
Zynerji
112
mantikos wrote:
31 Jul 2018, 21:47
GPR-A wrote:
31 Jul 2018, 16:10
Agreed, 100%
spamior00
spamior00
Hi, I'm new on this forum. I don't know is that thread was questioned on this forum, but is it possibile to exceed fuel flow limits in test? If yes, that Renault and Honda could set engine power on Mercedes and Ferarri level and even more to see what capable the chasis is. They could make it with Mclaren as well last year? However Hungary has to short straights to show diffrence.
