Toro Rosso STR14 speculation thread
carisi2k
27
Re: Toro Rosso STR14 speculation thread
nevill3 wrote:
26 Dec 2018, 15:50
All this talk of the whole rear end being supplied by RedBull to Toro Rosso forgets to menbtion that many other parts will come too. The drive train, gearbox and front suspension could be the same too. Only the chassis has to be designed by themselves and not another current racing team or a previously raced chassis ( of another team) either.
no but drawings can be diverted to faenza. It happened in 2008
cramr
cramr
carisi2k wrote:
27 Dec 2018, 04:30
If I'm not wrong that's highly ilegal with risk of both team losing all points and money
KingHamilton01
I think Given will be very similar to Red Bull chassis they will be a competitive outfit! Midfield fight is going to have a lot of teams fighting together imo.
McLaren Mercedes
From Autosport today.
As Red Bull will join Toro Rosso in using Honda engines in 2019, the junior team will use a Red Bull-designed rear-end as well as some front suspension parts.
Toro Rosso will utilise 2018 parts because Red Bull is famous for pushing its contemporary design as close to the start of the season as possible. :(
Marko said it was not logistically possible for Red Bull to produce enough parts for four cars without compromising pre-season preparations, but said Toro Rosso, which finished ninth of the 10 teams in 2018, must still target "fifth or sixth place". :(
"The concept is no longer a secret: Toro Rosso has received three trucks full of parts and will take over many parts of the 2018 car from Red Bull Racing, as far as the regulations allow," said Marko.
"The whole thing was made easier by the whole engine question.
"The complete rear end is from us, everything that is permitted according to the regulations.
"This gives us a small advantage on the cost side."
https://www.autosport.com/f1/news/14085 ... l-director
Godius
186
03 Jan 2019, 21:01
Reading this article and looking back at the end of last year when Honda introduced the Spec-3 but encountered some vibration issues on the STR13. I can now understand that nobody was really panicking about this issue because the test rig was probably already more engineered towards a RBR integration.
Zynerji
111
What is the maximum limitation here?
We know wings/bargeboards/brake shrouds need to be new for 2019.
Most internal parts are probably designed around the Renault installation.
Other than suspension, PU, and brakes, what could the 2019 STR use from the 2018 RBR?
Zynerji wrote:
10 Jan 2019, 00:00
Good question.
The back of the RB14 was build around the Renault PU and now the TR14 needs a rear designed around the Honda, but they get the Renault design.
AFAIK STR usually only get the RB/xtrack Gbox internals or the whole rear part of the RB Gbox and they design their own Gbox casing or their own bell-housing, to adappt the RB transmission to their engine...
So actually they'll continue to do the same in 2019;
-either they get the RB gbox internals (+ the suspensions this time - rear and front) and build a new bell-housing/casing...
-or they'll simply retain the whole 2018 RB gearbox which has been designed to host the whole Renault turbo (while in 2019 it will only have to accommodate the Honda turbine) so the 2018 RB gbox should have plenty of space...
Or, why not, they'll keep the whole 2018 STR 2018 gearbox or builld a fullly new one...
Dont' believe everything that big bullshitter Marko says anyway.
It seems some Marko fangirl (Or Helmut himself?) rated my message as baseless although it's based on facts.
gandharva
252
What you say was true for the past, so the downvote was not necessary. But in 2019 they aim for even tighter cooperation.
Franz Tost:
Speaking to Autosport, he said: "It was stupid, why should we make our own gearbox when we can get it from Red Bull?
"We have a synergy project, we have the rear end, we have parts from the front suspension, that's it.
"It's just totally simple, we have the Honda engine, we put on the Red Bull Technology gearbox, nothing more to say."
Committing to the same suspension will also mean that the two teams are likely to converge on an aerodynamic approach.
"We will have a very close cooperation with Red Bull Technology next year," said Tost.
"Because we will have the same rear part, which means the power unit, gearbox and the suspension - everything within the regulations - because we want to use this much.
"The front suspension as well, the inner parts, not the outer parts, that's all.
"But that's a lot, because you know the complete rear part means also the hydraulics, the electronics, all this kind of stuff."
https://finance.yahoo.com/news/red-bull ... ccounter=1
Toyoharu Tanabe seems to think that TR will also use RBR gearbox externals in 2019:
Usually, though it uses the same gearbox internals as Red Bull, Toro Rosso has opted to provide its own casing. This year however, both will run the same rear end including suspension, a move which Honda believes will greatly aid the Japanese manufacturer.
https://www.pitpass.com/63753/Shared-Re ... efit-Honda
I think they will use as much 2019 parts as allowed to decrease costs and also make it easier for Honda to push on the engine side. I would'n t be too surprised if the STR14 will look like RB14 in terms of aerodynamics.
ScrewCaptain27
577
Livery will be the same, this is the 2018 car though.
Launch on February 11th
- Serj Tankian
_cerber1
266
Photo STR 13?
gandharva
252
_cerber1 wrote:
25 Jan 2019, 12:46
Photo STR 13?
I think so.
ispano6
158
How does anyone know if the livery is going to be the same?
Based on photo comparisons between RB14 and STR13, I am of the opinion the biggest improvements for the STR14 may likely be the front suspension arms and the suspension hardware (namely the front hydraulic j-damper). The RB14's suspension arms were also far less bulky than the STR13's.
https://us.motorsport.com/f1/news/how-r ... 5/3061225/
gandharva
252
Launch will be 14:30 CET.
Friendly reminder we will be closing this topic 14:30 CET due the car launch event. A soon as we have official media, the official car thread will go open.
The stream will be held at their official youtube channel, keep an eye out on there and their official website & twitter account:
https://www.youtube.com/user/ToroRossoOfficial
Keep a close eye out for their twitter account and website:
https://twitter.com/ToroRosso
https://scuderiatororosso.redbull.com/en_INT
