How accurate is our "cheap" CFD ?
Uwe
Uwe
Re: How accurate is our "cheap" CFD ?
Hoffman900 wrote:
19 Dec 2020, 22:19
From a Boeing friend, I don't think they would put much stock into low end CFDs on desktop computers, except for some very course measurements (maybe). That said, airplane aerodynamicists have to work with a greater factor of safety and confidence than even F1 designers.
I think F1 aerodynamics is far more complex than in aviation.
F1 has lots of aerodynamics sick complex parts that aircraft not need..
Jolle
Jolle
133
Zynerji wrote:
19 Dec 2020, 21:17
LM10 wrote:
19 Dec 2020, 21:10
Talking about CFD at home, a bit offtopic: How is the FIA managing the ban on CFD work for the 2022 car for instance? What if engineers simply start their home computer and do some CFD?
I'm absolutely sure there is some of this going on, and if F1/FIA doesn't know, it is ridiculous. Especially with blockchain tech. A team could have given each engineer a 64core Threadripper with 512GB RAM, multiple GPU desktop to take home, while having a distributed blockchain CFD cruncher running in the background. Get 300-400 of these rigs up and running, and you could be doing some serious crunching in a 100% invisible, un-auditable way...
A lot of these rules are under a gentleman's agreement and good sportsmanship. There are many ways around these rules if they wanted to. It's in the interest of all investors into the sport that this play field is levelled to some degree, else spending (and financial results) would go haywire again. As for CFD work, I assume everything is done by remote sessions on the network back in base. Not just to monitor the rules, but also for safety.
n_anirudh
n_anirudh
Personally, I think accuracy is the "wrong" question to be asking as many previous posters have said. For instance, researchers may look at wakes of tractor-trailers and come up with a particular flow topology when they run LES; but may end up with a completely different flow topology whilst using a different turbulence model/numerical scheme or a method. This may happen in F1 with RANS predicting one type of flow state, while another may exist in the wind tunnel.
In my experience, researchers of automotive hatchbacks traditionally use the Ahmed body as a benchmark - but a standard body actually lies at the cusp of two different flow states (wrt to its width, back slant angle etc); and would be a bad starting point for someone to use the experimental data to tune CFD models.
These are small issues compared to what F1 teams usually look at - performance modelling and perhaps 0D or 1D models for initial assessment
Hoffman900
Hoffman900
219
Uwe wrote:
20 Dec 2020, 00:26
Hoffman900 wrote:
19 Dec 2020, 22:19
Not at all. Ever look at a wing and all the control elements? Also, planes have a much further range of speed (MUCH higher than Formula 1), pitch, temperature changes (air density), crosswinds / downwinds / updrafts / downdrafts, balance, etc. then add in the factor of safety aspect of it all.
The smartest aerodynamics folks are aerospace for a reason (and get paid accordingly) and why they have MUCH more computing power than any F1 teams. This isn't a slight on the intelligence in F1 either, incredibly smart people there too, but there are just less brains (it's a smaller industry). Don't confuse little add on vortex generators and the like with complexity. Sure, it's not easy, they are two different disciplines and people know that, but aircraft (to do it well and reliably) are hard. I really don't know if I would be confident enough to fly in a plane designed by Ferrari's aero department :shock:
Remember, even aircraft aerodynamicists understand and use vortex generators. They have been playing with them well before Formula 1 did. There is a famous crash of the XB-70 in 1966 where a F-104 got sucked into the wing tip wake vortex and crashed into it.
Uwe
Uwe
Hoffman900 wrote:
20 Dec 2020, 02:52
Uwe wrote:
20 Dec 2020, 00:26
Hoffman900 wrote:
19 Dec 2020, 22:19
Greater speed dont make calculation more complex,execept we are going into supersonic speeds.
Aircraft dont have and it will never has spliters,gurney flaps,tyres,suspensions,mirrors,sidepod,shark fin,diffuser,side duct,DRS,side skirt,canards,spoilers,moving ground,etc etc etc etc etc
Puting all this thousendes thing all together make F1 extremly more complex to solve in one CFD software..
Airflow around F1 car is far more complex/turbulent then aorund any aircraft,separated flow and turbulence is almost impossible to solve with any CFD with great accuracy..
jjn9128
779
Uwe wrote:
20 Dec 2020, 10:10
Errrrrr Gurney flaps were called Nolders before Dan Gurney first used one. Most F1 tech comes from aerospace, only thing I can think of going the other way is moving ground plane in a wind tunnel.
Aerospace and motorsport aerodynamicists are the same people - some go from one industry to the other.
#aerogandalf
Uwe
Uwe
jjn9128 wrote:
20 Dec 2020, 10:15
Uwe wrote:
20 Dec 2020, 10:10
I just want to say that airflow around F1 car is far more complex turbulent then around aircraft...so it must be harder to solve for CFD,much harder..
Uwe
Uwe
jjn9128 wrote:
19 Dec 2020, 22:37
Heck anyone can buy time on an HPC relatively cheaply nowadays, don't even have to simulate it on your home PC. Really depends how accurate you want to go, the sort of mesh you can run now on a home PC in a day is within 1% of real world data. Or you can run on a Chinese HPC with 80 billion cells and get within 0.5% :lol:
Uwe
Uwe
Hoffman900 wrote:
20 Dec 2020, 02:52
Uwe wrote:
20 Dec 2020, 00:26
Hoffman900 wrote:
19 Dec 2020, 22:19
I think F1 rear wing has all aerodynamics in it, that airliners need to fly...
F1 much more complex to solve
Uwe wrote:
20 Dec 2020, 10:31
jjn9128 wrote:
20 Dec 2020, 10:15
Uwe wrote:
20 Dec 2020, 10:10
An airliner at cruise, yes. That same airliner on approach with landing gear down, flaps and slats extended, the effect of changing configurations, add in a cross wind too, is a different thing again.
Uwe
Uwe
Just_a_fan wrote:
20 Dec 2020, 13:19
Uwe wrote:
20 Dec 2020, 10:31
jjn9128 wrote:
20 Dec 2020, 10:15
All aircrafts are design for cruise flight.
They dont care about wheels/gear aerodanyamics like F1 do, F1 wheels are critical part how airflow will moving around car and has great influenece of car performance.
F1 even must include rotating wheels in calculations becuase stationary wheels give completly wrong results
for example airliners dont include rotating fan at turbo fan engine when simulate plane flight...
jjn9128
779
Hoffman900 wrote:
19 Dec 2020, 23:09
That seems optimistic. 1% is for what kind of design? A glider or a F1 car? How do you know what 1% is if you have nothing to go off of?
From an engineering side, just throwing a general value of 1% out there is kind of reckless without qualifying it.
You're right I was exaggerating for effect, one should never engage in hyperbole on internet forums. I have seen a paper comparing 35million cells to 2.3billion cells to experimental data, for automotive so large separated regions, and the difference is not all that great a few percent at most.
#aerogandalf
jjn9128
779
Uwe wrote:
20 Dec 2020, 13:11
Aviation isn't subject to some arbitrary resource requirement though, a lot of F1 (in the recent past at least) is RANS because they can churn though quite fast before going into LES/DES for more detailed work before signing off parts.
Dont' see the need for all this willy waving, both are complex problems.
#aerogandalf
Hoffman900
Hoffman900
219
Uwe wrote:
20 Dec 2020, 13:36
Just_a_fan wrote:
20 Dec 2020, 13:19
Uwe wrote:
20 Dec 2020, 10:31
I think you’re grossly underestimating things. Both are complex problems though and there is respect from both, for both disciplines within the aerodynamics community.
Hoffman900
Hoffman900
219
jjn9128 wrote:
20 Dec 2020, 13:57
Hoffman900 wrote:
19 Dec 2020, 23:09
Right. I think the computing power is accessible to get pretty close from home (by renting time on clusters (I believe Fluent has this available)), but it’s the calibration of the model that is well beyond what anyone can do at home.
Even CFD of the a cylinder head / intake tract is going to require building an instrumented engine at some point, which depending on the performance envelope, can get pretty pricy (tens of thousands of dollars). You still need to establish the in cylinder pressure curve, which will effect your cfd model as well as ideally measuring port pressure for confirmation. You can use a 1d pressure dynamics sim to do help with development, but at some point, you need to calibrate that too.
