McLaren MCL36 Speculation Thread
billamend
billamend
Re: McLaren MCL36 Speculation Thread
Stu
billamend wrote:
08 Jan 2022, 00:23
I only said the other day that I doubt we will see a pull-rod front suspension and how much of a shame I thought that would be!!
Hoffman900
Hoffman900
219
Does it allow for more travel in regards to how it’s packaged in these cars?
jacobianminkowski
jacobianminkowski
-1
BlueCheetah66 wrote:
07 Jan 2022, 21:20
There's two things I've noticed in those pictures. The sidepods seem to be quite low down compared to the bulkhead. Also, I'm not sure if this is just the lighting but it looks like they are following the same style of a quick thinning of the nose at the end of the chassis bulkhead
don't think that team will be doing that with the new regulations. its probably just round at the top like in this image.
_cerber1
266
Changes to the Pull Rod suspension are possible, Skarb said. What can this potentially give us?
Stu
_cerber1 wrote:
08 Jan 2022, 10:06
https://pbs.twimg.com/media/FIiPlAJWUAM ... name=large
In the picture that you have shown it would not work great (high chassis structure, poor load paths), but if you go for a lower chassis structure (and nose) the main elements of the sprung part of the suspension can be mounted lower, a pull-rod can be made very thin (as it operates in tension at all times - great news for CFRP!).
Downsides are that suspension elements become awkward to access (but with the minimal changes to cars trackside this is not too much of a downside! The other big downside is that more bulk tends to be added to the chassis low down, which can have an impact on aero performance.
To see how tidy this layout can be look at the McLaren MP4/4, that car was not too shoddy….
https://cdn.motorsportmagazine.com/wp-c ... -Senna.jpg
And could a pull rod be better for downwash in this case?
ScrewCaptain27
577
Blackout wrote:
08 Jan 2022, 12:11
Not sure, that would depend on how high the front of the chassis is. If the chassis is quite low (like on more modern pull-rod cars such as the Arrows A21 or Minardi PS01) the arms can be nearly parallel to the ground and the pullrod can be made very thin, which will reduce drag and weight.
- Serj Tankian
timbo
timbo
113
If I understand the 2022 regs correctly, the suspension arms must be connected to the wheel within the "wheel rim". So it is impossible to use specially shaped uprights to raise the arms as much as possible anymore.
So if it is impossible to move suspension members out of the airflow, maybe the idea is to somehow use the front suspension arms as flow conditioners, such as already done with the rear suspension?
ScrewCaptain27
577
timbo wrote:
08 Jan 2022, 13:10
They have been used as flow conditioners since the 1990s
- Serj Tankian
timbo
timbo
113
ScrewCaptain27 wrote:
08 Jan 2022, 13:14
timbo wrote:
08 Jan 2022, 13:10
Yes, I meant even more so.
Recently the trend was to remove them from the flow going to the splitter/over the floor.
jjn9128
779
Stu wrote:
08 Jan 2022, 10:29
_cerber1 wrote:
08 Jan 2022, 10:06
The front of the tub isn't much lower in '22.
#aerogandalf
Stu
jjn9128 wrote:
08 Jan 2022, 15:15
Stu wrote:
08 Jan 2022, 10:29
_cerber1 wrote:
08 Jan 2022, 10:06
Which makes going to pull rods awkward. I’ve thought of another drawback. The teams are all using pushrod offset to control low speed weight distribution; limited for this year, but there will still be a benefit to using pushrods.
Tunnel sizes may now put an end to pull rods at the rear too.
jjn9128
779
Stu wrote:
08 Jan 2022, 16:05
I don't think the tunnel height is a limiting factor (very much WIP)
#aerogandalf
timbo
timbo
113
jjn9128 wrote:
08 Jan 2022, 17:27
Stu wrote:
08 Jan 2022, 16:05
https://db3pap006files.storage.live.com ... pmode=none
So the driveshaft will be practically lying on the tunnel top?
